[Qgis-developer] [QGIS Commit] [qgis/Quantum-GIS] d77973: Revert "Fix from lynxlynxlynxlynxlynx for building...
欧阳乐岩 ouyang.leyan at hotmail.com
Fri Sep 7 03:00:28 PDT 2012
I am unable to compile the latest QGis, I guess this is the same issue?
(I am using ArchLinux)
[ 47%] Built target qgis.d.rast
Linking C executable ../../../output/lib/qgis/grass/modules/qgis.g.info
/usr/bin/ld: CMakeFiles/qgis.g.info.dir/qgis.g.info.c.o: undefined
reference to symbol 'pow@@GLIBC_2.0'
/usr/bin/ld: note: 'pow@@GLIBC_2.0' is defined in DSO /usr/lib/libm.so.6
so try adding it to the linker command line
/usr/lib/libm.so.6: could not read symbols: Invalid operation
On 09/07/2012 04:08 PM, Tim Sutton wrote:
> Hi
> On Thu, Sep 6, 2012 at 4:33 PM, William Kyngesburye
> <woklist at kyngchaos.com> wrote:
>> Tim, do you know what problem this was meant to fix?
> It seems to be an edge case where lynxlynxlynx has a grass install
> that is not linked to libm
> 14:05:32	lynxlynxlynx:	it's not osx, i'm on linux
> 14:05:38	timlinux:	lynxlynxlynx: oh
> 14:05:51	timlinux:	I wonder why only you had that compile issue
> 14:06:12	lynxlynxlynx:	probably my grass doesn't have -lm stored in its pc file
> 14:07:17	timlinux:	lynxlynxlynx: I will revert it for now
> 14:08:08	lynxlynxlynx:	wrap it in a windows check
> 14:09:05	lynxlynxlynx:	or msvc specifically, if mingw is supported
> 14:09:07	GitHub59:	[Quantum-GIS] timlinux pushed 2 new commits to
> master: http://git.io/wdmTfQ
> 14:09:07	GitHub59:	[Quantum-GIS/master] Revert "Fix from
> lynxlynxlynxlynxlynx for building grass on mac" - Tim Sutton
> Regards
> Tim
>> On Sep 6, 2012, at 9:01 AM, GitHub wrote:
>>>   Branch: refs/heads/master
>>>   Home:   https://github.com/qgis/Quantum-GIS
>>>   Commit: d77973d0d3a126190656b9297c724c680a67d38b
>>>       https://github.com/qgis/Quantum-GIS/commit/d77973d0d3a126190656b9297c724c680a67d38b
>>>   Author: Tim Sutton <tim at linfiniti.com>
>>>   Date:   2012-09-06 (Thu, 06 Sep 2012)
>>>   Changed paths:
>>>     M src/providers/grass/CMakeLists.txt
>>>   Log Message:
>>>   Revert "Fix from lynxlynxlynxlynxlynx for building grass on mac"
>>> This reverts commit 977518af3a669aac1045eebb5b00fce2b6d50680.
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> Theory of the Universe
>> There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable.  There is another theory which states that this has already happened.
>> -Hitchhiker's Guide to the Galaxy 2nd season intro
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
