[Qgis-developer] Upgraded collapsible groupboxes
Larry Shaffer larrys at dakotacarto.com
Wed Sep 12 22:02:29 PDT 2012
On Wed, Sep 12, 2012 at 11:00 AM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> Hi, thanks for your input
> I have tried to fix that issue, but didn't find a working solution yet
> (there is code in there addressing that issue). I think that Qt does
> not scroll down, because part of the widget is already visible. If
> anyone has a suggestion I would appreciate it.
Not sure how that would be possible from the QgsCollapsibleGroupBox
class, since the custom groupbox could be placed anywhere, not just in
a scroll area. What Leyan is suggesting (I think) would have to be
some slot in the dialog's class that catches the signal when one of
its children collapsible groupboxes is expanded, then figures the
current scroll position of the groupbox and how much of it is hidden,
then scrolls appropriately to expose the whole groupbox.
This would be somewhat similar to toolbox behavior, though without the
horrible 'hide everything else' aspect of that widget. A nice feature
to have, but probably a pain to add to many dialogs... unless we
create a custom Designer plugin scroll area class with such a slot so
that the signal of every collapsible groupbox it contains could be
assigned to it in Designer. The QgsCollapsibleGroupBox class would
also have to be a QtDesigner plugin, which Etienne has already worked
on.
Regards,
Larry
> Etienne
> On Wed, Sep 12, 2012 at 12:46 PM, 欧阳乐岩 <ouyang.leyan at hotmail.com> wrote:
>> On 09/12/2012 02:15 AM, Larry Shaffer wrote:
>>> Hi,
>>> Over the past couple of days Etienne Tourigny and I have upgraded the
>>> functionality of the QgsCollapsibleGroupBox class he recently
>>> introduced. The changes have been pushed to master branch and can be
>>> seen in the Save As... dialog for raster layers and in the scroll
>>> areas of the 3 tabs in the PAL Labeling options.
>>> We have tested on some Linux versions and on Mac. *Feedback on the
>>> look and functionality, as well as any OS-specific issues, would be
>>> greatly appreciated.* It would be best to make sure these new changes
>>> work on (hopefully) every supported platform before using them more
>>> extensively.
>> Hi,
>> It seems to be working well for me (compiled under Archlinux). Just one
>> small remark:
>> * For a long dialog like "Save as ..." for rasters, I need to scroll to see
>> everything. When the "Pyramids" groupbox is closed, the area scrolls
>> automatically to hide the resulting blank space, which is nice. However,
>> when opening the "Pyramids" groupbox, the dialog does not scroll down to
>> show the newly visible options. It would be nice to show them, as if we open
>> the groupbox we are probably interested in its content.
>> Regards,
>> Leyan
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
