[Qgis-developer] Default typeface to package with app
Larry Shaffer larrys at dakotacarto.com
Mon Sep 17 21:23:54 PDT 2012
Hi Alister,
On Mon, Sep 17, 2012 at 5:10 PM, Alister Hood
<Alister.Hood at synergine.com> wrote:
> Hi guys,
> Including a standard font has obvious benefits for testing labelling etc, but I'm wondering if the benefits of using it for the gui aren't wishful thinking.
> I think it is essential to allow the user to be able to control the font size (preferably by obeying the system font settings), as some screens are at least twice the DPI of other screens, and some people need larger fonts due to eye problems (personally, I usually find applications that specify their font offensive because it is too _big_, and typically they also either force blurry antialiased rendering, or a font which looks awful with antialiasing and cleartype disabled).
> If someone was using a larger font than the "standard", would you say, "sorry, that's not a bug, use the standard font"?
> Surely it is better to focus on accessibility, making a gui that can cope with different font settings?
> Or am I missing something?  Would you design the gui to make sure it works with the standard font at multiple sizes?
I'm not suggesting that the app have a fixed font size across
platforms or per platform.
I'm proposing a standardized typeface; one that has been tested, with
known results and known metrics. Beyond those base requirements, and
regarding font size, sensible defaults per platform/device would need
set to account for differences like OS conventions and dpi. Right now,
QGIS completely relies upon Qt to do this (other than overriding the
entire app's relative font size) with varying degrees of success;
especially concerning Python plugins, where it's not uncommon to find
hard-coded point sizes that are completely illegible, or too big, on
some platforms.
Ideally, I see the use of Qt stylesheets, with reasonable
platform-specific defaults that can be programmatically adjusted or
generated relative to user preferences, as a good candidate. Depending
upon the implementation, even the base defaults could be editable
without recompiling.
Qt stylesheets are inherited down the Qt object parent-child tree
(even down to PyQGIS plugins), and can be overridden or set via many
selectors. This will allow the user to choose not only the size they
want to use in general, but possibly what size they want for a
particular Qt class of object (within reason, and relative to how devs
think the app components should be classified and styled).
For example QGIS already sets its main font with a stylesheet:
  setStyleSheet( QString( "font-size: %1pt; " ).arg( fontSize ) );
but hard-codes the status bar, regardless of platform (rather limiting):
  QFont myFont( "Arial", 9 );
For testing, I would assume the standard font should look OK within a
reasonable range for a given widget, e.g. default at 12, but looks and
functions reasonably well 3 pt sizes above/below for accessibility
concerns. We can use the current Qt- and OS-produced sizes as a
starting point and tweak from there.
In general, when the app ships as a release, we would know what it
looks like on most, if not all, supported platforms when using the
standard typeface, regardless of what the user may change, or Qt would
have changed, afterwards. Trying to troubleshoot any font the user
might choose could be a nightmare; nonetheless, offering the user the
ability to choose their own font should probably still be implemented.
Regards,
Larry
> Note: unlike other QT applications, at least on Windows QGIS currently ignores the system font size (and there is no qtconfig available on Windows)... I would consider this to be a bug.
> Regards,
> Alister
> Qgis-developer mailing list
