[Qgis-developer] [Qgis-user] Sextante - error saving a model with Select by location tool
Victor Olaya volayaf at gmail.com
Mon Sep 17 23:36:40 PDT 2012
Hi Pedro
The problem is that the select algorithm does not generate a new
layer, but just makes a selection on a existing one. It seems that
this case hasn't been correctly considered...
I will have a look at it and see if I can fix it
Regards
2012/9/18 Pedro Venâncio <pedrongvenancio at yahoo.com>:
> Hi,
> I can not save a model in which is used the tool 'Select by location' from fTools.
> When saving, it shows the error:
> An error has occured while executing Python code:
> Traceback (most recent call last):
>   File "/home/pedro/.qgis//python/plugins/sextante/modeler/ModelerDialog.py", line 219, in saveModel
>     text = self.alg.serialize()
>   File "/home/pedro/.qgis//python/plugins/sextante/modeler/ModelerAlgorithm.py", line 305, in serialize
>     s+=unicode(self.algOutputs[i][out.name]) + "\n"
> KeyError: 'OUTPUT'
> Python version:
> 2.7.3 (default, Aug  1 2012, 05:27:35)
> [GCC 4.6.3]
> QGIS version:
> 1.9.0-Master Master, exported
> Python path: ['/home/pedro/.qgis//python/plugins/ogrprocessing', '/home/pedro/.qgis//python/plugins/sextante', '/usr/share/qgis/python', '/home/pedro/.qgis//python', '/home/pedro/.qgis//python/plugins', '/usr/share/qgis/python/plugins', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL', '/usr/lib/python2.7/dist-packages/gst-0.10', '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7', '/usr/lib/python2.7/dist-packages/ubuntu-sso-client', '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode', '/home/pedro/.qgis/python/plugins/mmqgis/forms', '/home/pedro/.qgis/python/plugins/qgis2kml', '/home/pedro/.qgis/python/plugins/qgis2kml', '/usr/share/qgis/python/plugins/fTools/tools']
> And then, when I try to remove the module 'Select by location' from the model, it shows the error:
>   File "/home/pedro/.qgis//python/plugins/sextante/modeler/ModelerGraphicItem.py", line 89, in removeElement
>     if not self.model.removeAlgorithm(self.elementIndex):
>   File "/home/pedro/.qgis//python/plugins/sextante/modeler/ModelerAlgorithm.py", line 164, in removeAlgorithm
>     val = self.algOutputs[index][out.name]
> KeyError: 'OUTPUT'
> Python version:
> [GCC 4.6.3]
> Which will be the problem?
> Thank you very much!
> Best regards,
> Pedro Venâncio
> Qgis-user mailing list
