[Qgis-developer] qt at digia
Tim Sutton lists at linfiniti.com
Sat Sep 22 13:15:30 PDT 2012
Hi
On Sat, Sep 22, 2012 at 1:13 AM, John C. Tull <jctull at gmail.com> wrote:
8<----------snip---------------
>>> Beside some smaller issues the current state of master seems useable
>>> and stable to me ..
>> [1] http://semver.org/
> Presumably, Qt5 would lead to some new broken api's relative to what has been done in trunk towards the 2.0 release, but confirm if that is a valid assumption or not. If it is, maybe a qgis 2.2 or higher release is a more sensible target for the switch. If not, then it is more a matter of how long transitioning and testing would take.
With such a big underlying change I would be inclined to make a make
version release (be it 2.0, 3.0 or what ever). My understanding is
that Qt5 is far more backwards compatible that Qt4 was and the impacts
to end users / developers should be minimal (other than new Qt5
dependency).
Regards
Tim
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
