[Qgis-developer] Tickets for plugins
Etienne Tourigny etourigny.dev at gmail.com
Fri Sep 28 12:00:57 PDT 2012
When I login I can create new issues there (but I have  dev permissions)
On Fri, Sep 28, 2012 at 3:36 PM, Agustin Lobo <alobolistas at gmail.com> wrote:
> I was trying here:
> http://hub.qgis.org/projects/qgis-user-plugins/issues
> Reported now. Thanks
> Agus
> On Fri, Sep 28, 2012 at 8:16 PM, Alex Mandel <tech_dev at wildintellect.com> wrote:
>> On 09/28/2012 10:28 AM, Agustin Lobo wrote:
>>> I've tried to add a ticket for plugin "Add Pin" and get
>>> "No tracker is associated to this project. Please check the Project settings."
>>> if I have User plugins selected on the upper right corner
>>> How do I open a ticket for this plugin that does not work (the point
>>> is not drawn)
>>> in 1.8. for linux? (works on mac and works with 1.7.4 on linux)
>>> Agus
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Are you talking about the PinPoint plugin?
>> http://hub.qgis.org/projects/pinpoint
>> Were you logged in? Once logged in do you see a New Issue menu item?
>> It does appear to have a tracker but I might need to check the
>> permissions on who can add Issues.
>> Thanks,
>> Alex
