[Qgis-developer] Inconsistant use of VSIMalloc() / malloc() and VSIFree() / free()
Even Rouault even.rouault at mines-paris.org
Fri Sep 28 13:45:01 PDT 2012
I'm running QGIS master with a GDAL trunk built with a mechanism to detect
unbalanced use of VSIMalloc() and VSIFree().
To enable it, edit gdal/port/cpl_vsisimple.cpp and uncomment the //#define
DEBUG_VSIMALLOC line at the beginning of the file. When this is enabled, the
pointer returned by VSIMalloc() shouldn't be passed to free(). And if
VSIFree() is provided a pointer allocated by malloc(), it will abort.
This is mainly usefull to detect issues on Windows : if QGIS and GDAL are
built with different MSVC versions, the C runtimes might not be compatible, and
a free() done in DLL A of a pointer allocated by malloc() in a DLL B might
crash. For example, when called from QGIS, free(VSIMalloc()) or
VSIFree(malloc()) can result in crashes.
And indeed I get crashes in QGIS when it is enabled, for example on the free()
in qgsrasterdrawer.cpp:73
I've searched in QGIS code and I can see that several classes implement void *
XXXXX::readBlock( int bandNo, QgsRectangle  const & extent, int width, int
height ), but they return a buffer sometimes allocated by malloc(), or
sometimes by VSIMalloc().
Some choice must be made ... My intuition would be that using regular malloc()
/ free() would be better.
Basically, you would restrict the use of VSIFree() to only strings/buffers
returned by GDAL. To avoid unnecessary changes in existing code, balanced use
of VSIMalloc() / VSIFree() in the context of a method is OK. The real issue is
when a method returns a void* pointer and you don't know which free function
must be called on it.
Best regards,
Even
PS: The same holds for CPLMalloc() / CPLFree(). In the context of the above
analysis, they can be considered as strictly equivalent to VSIMalloc() /
VSIFree().
