[Qgis-developer] Rename through add vector file
Antonio Locandro
antoniolocandro at hotmail.com
Mon Apr 8 10:01:34 PDT 2013
I was adding a *.shp with the add vector dialog, since it let me rename I renamed it and proceed to adding giving me an error. After opening the folder where I had the *.shp it became apparent that the problem is it only renamed one of the files associated with shapefile. So the correct behavior should to not allow renaming of shapefiles or that renaming of the shapefile renames all the files associated to it (similar to what you can do with ArcCatalog of ESRI)
Thoughts?
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130408/98f70c39/attachment.html>
