[Qgis-developer] Mac enviromental variable problem
Larry Shaffer larrys at dakotacarto.com
Tue Apr 9 03:24:55 PDT 2013
Hi Francesco,
On Tue, Apr 9, 2013 at 2:06 AM, francescoboccacci at libero.it <
francescoboccacci at libero.it> wrote:
> Hi all,
> i have a question about enviromental variable on Mac.
> From python shell i can import psycopg2 module. If i use Python console
> from
> QGIS this module it can found.
> I have to write:
> import sys
> sys.path.append('/opt/local/Library/Frameworks/Python.framework/Versions/2.
> 7/lib/python2.7/site-packages/')
> import psycopg2
> and now it works.
> How can fix it adding  permanently to QGIS enviromental variable?
Consult this recent discussion:
http://osgeo-org.1560.x6.nabble.com/error-running-qgis-master-sextante-depends-on-psycopg2-but-this-dependency-isn-t-well-known-td5023977.html#a5042252
Basically, if you are using QGIS installed via kyngchaos or the nightly,
the app is built against Apple's system Python. As such, it looks for
modules installed in /Library/Python/2.7/site-packages, not under /opt.
Kyngchaos.com has an installer for that module that will properly install,
so that QGIS will find it.
http://www.kyngchaos.com/software/python
There are other solutions, but that is the simplest.
Regards,
Larry
> Thanks
> Francesco
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130409/1e4419ac/attachment-0001.html>
