[Qgis-developer] QGIS globe and mapserver export plugin
Luca Delucchi lucadeluge at gmail.com
Thu Apr 11 05:04:31 PDT 2013
On 11 April 2013 12:51, Paolo Cavallini <cavallini at faunalia.it> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Il 11/04/2013 12:44, Luca Delucchi ha scritto:
>> Where is RT Mapserver Exporter plugin? I look for it in plugin
>> manager but I cannot find  it.
> Please enable experimental plugins: it's there.
found
with postgis layer with no password stored it return this error
An error has occured while executing Python code:
  File "/home/lucadelu/.qgis2/python/plugins/rt_mapserver_exporter/mapfileexportdlg.py",
line 353, in accept
    if mapscript.MS_SUCCESS != ms_layer.applySLD( sldContents, ms_layer.name ):
MapServerError: msPostGISLayerOpen(): Query error. Database connection
failed (fe_sendauth: no password supplied
) with connect string 'dbname='*********' host=********** port=5432
user='*******' sslmode=disable'
Is the database running? Is it allowing connections? Does the
specified user exist? Is the password valid? Is the database on the
standard port?
Could be perfect if it could open a dialog and digit the password
> All the best.
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
