[Qgis-developer] qgis web client, GlobalOptions and GISProjectListing parameters
Bernhard Ströbl bernhard.stroebl at jena.de
Fri Apr 12 01:57:32 PDT 2013
Hi Giovanni,
AFAIK this is not possible at the moment, but there is a ticket open for
a language switcher [1]
If I had several CRS I would create different installations of QWC, you
cannot access the projects with the themeSwitcher in this case but that
would probably fail anyways because changing the theme keeps the current
bounding box which would be of no use if the other theme has a different
CRS (or is defined for a different place of the world). Could you
describe your use case for using different CRS for the same place?
Bernhard
[1] http://hub.qgis.org/issues/5166
Am 12.04.2013 10:32, schrieb Giovanni Manghi:
> Hi all,
> in qgis web client it is possible to use (via url or theme switcher) a
> config file different from GlobalOptions.js ?
> What I would like to achieve is to use the theme switcher to publish
> themes with different languages,CRS and maybe other things defined in
> GlobalOptions.js
> Another way would be allow set them in GISProjectListing.js
> Is this possible at the moment?
> Thanks in advance
> -- Giovanni --
__________ Information from ESET Mail Security, version of virus signature database 8220 (20130412) __________
The message was checked by ESET Mail Security.
http://www.eset.com
