[Qgis-developer] Postponement of 2.0 API freeze until April 22
Tim Sutton lists at linfiniti.com
Mon Apr 15 10:32:04 PDT 2013
Hi All
According to our release roadmap (see below) we should be entering API
freeze today. However there are some bad inconsistencies in the API.
Here is an example from QgsCoordinateTransform:
['ForwardTransform', 'ReverseTransform', 'TransformDirection',
'__class__', '__delattr__', '__dict__', '__doc__', '__format__',
'__getattr__', '__getattribute__', '__hash__', '__init__',
'__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__',
'__setattr__', '__sizeof__', '__str__', '__subclasshook__',
'__weakref__', 'blockSignals', 'childEvent', 'children', 'connect',
'connectNotify', 'customEvent', 'deleteLater', 'destCRS', 'destroyed',
'disconnect', 'disconnectNotify', 'dumpObjectInfo', 'dumpObjectTree',
'dynamicPropertyNames', 'emit', 'event', 'eventFilter', 'findChild',
'findChildren', 'inherits', 'initialise', 'installEventFilter',
'invalidTransformInput', 'isInitialised', 'isShortCircuited',
'isWidgetType', 'killTimer', 'metaObject', 'moveToThread',
'objectName', 'parent', 'property', 'pyqtConfigure', 'readXML',
'receivers', 'removeEventFilter', 'sender', 'senderSignalIndex',
'setDestCRS', 'setDestCRSID', 'setObjectName', 'setParent',
'setProperty', 'setSourceCrs', 'signalsBlocked', 'sourceCrs',
'startTimer', 'staticMetaObject', 'thread', 'timerEvent', 'tr',
'trUtf8', 'transform', 'transformBoundingBox', 'transformCoords',
'transformInPlace', 'writeXML']
So we have setSourceCrs and setDestCRS - pretty much conforming to the
principle of *most* surprise. I just mention this as an example to go
along with this appeal: Lets extend the API freeze until the 22nd and
spend a few days going over your favourite classes to make sure the
public API is logical and consistent, otherwise we are going to be
stuck making band aid fixes for the next 5 years :-P
Updated roadmap:
1 April 2013 - Feature freeze - no new features in master.
22 April 2013 - API Freeze - no changes to API except where it is in
direct response to broken functionality.
30 April - GUI Freeze and String freeze - no changes to ui or strings
except where required for critical bug fixes. Call for translations.
1 June 2013 - Branch 2.0, code freeze (except for packaging related
changes), call for packaging.
7 June 2013 - Public release of 2.0
Regards
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
