[Qgis-developer] Icon theme update
Larry Shaffer larrys at dakotacarto.com
Mon Apr 15 19:42:14 PDT 2013
Hi Noli,
On Mon, Apr 15, 2013 at 7:00 PM, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Larry,
> What is the summary of this posting?
Some time ago, devs voted to move to the 'gis' theme as the default, i.e.
not just the one selected by default but also the only theme supported by
the project. Even after this update, you may notice the icons are still
hodge-podge with inconsistent ones needing work. Due to lack of developers
to maintain multiple project-supported themes, it is best to have only one,
so that a concerted effort can be made to keep it complete and cohesive.
Does mean that we can use themes in QGIS 2.0?
No theme support code was removed, only the gis theme condensed upon the
current default (because many default icons are still used) and old project
themes removed. However, there has been talk of removing all theme support,
but I can't speak to the state of that decision.
I like to revive my nkids theme for QGIS 2.0 as option for Mac OS X
> QGIS, is this possible?
I'm not entirely sure, but to use a different theme than the default, you
will need to add it to the appropriate source directories, edit the .qrc
files and compile the source again. For example, nkids has been in the
source themes directory for awhile, but not choose-able in the gui because
it is not been made part of compiled-in resource system.
I did add some code to push any old saved theme choice over to the new
default, so if you did add a revamped nkids theme, maybe considering giving
it a new name as well.
If I am misunderstanding the current state of decisions regarding the move
forward for icon themes, somebody please correct me (see also [0]).
Regards,
Larry
[0] http://hub.qgis.org/issues/7551
Thanks.
> Noli
> On 4/16/13, Larry Shaffer <larrys at dakotacarto.com> wrote:
> > Hi,
> > So, I've pushed a large update to master that condenses down the default
> > icon theme by overriding it with the gis theme (the theme voted to be the
> > replacement). I apologize if the change is abrupt, but it needed done
> with
> > enough time to edit/fix things before 2.0 release.
> > I did this in the following manner:
> > 1) Copied the gis theme over the default theme. Any files of same name
> were
> > replaced, missing files added. The was done for plugins that also managed
> > icon sets per theme (grass, georeferencer and ftools).
> > The state of previous icon theme sets and directory structure are
> preserved
> > as a download here [0] (saves switching local or browsing online git repo
> > to find replaced/removed ones). These can be added back to source
> > directory, for reference, or not.
> > 2) Updated all appropriate .qrc and .ui files that referenced old theme
> > paths.
> > 3) Switched some icons to improve consistency (mostly to + and - icons
> for
> > table widget row editing)
> > 4) Proofed every dialog I could think of, though I'm sure I missed
> > something. This was from both running from build directory and from
> > installed app on Mac.
> > 5) Added some code to ensure any old saved theme choice now goes to
> > default. No theme support code was removed.
> > 6) Updated CMakeList.txt files to ensure SVGs are also copied on install.
> > Where to go from here:
> > * Please, let me know if I made a mistake somewhere.
> > * We now have a single set of icons on which to work and update. Icons
> > should be updated, especially those that don't match current theme.
> > * Moving to SVG can be aided by leaving the getThemeIcon/Pixmap calls and
> > referencing the file by base name, without extension, e.g.
> > QgsApplication::getThemePixmap( "pie-chart" ). When using this technique,
> > as soon as a .png is replaced with a .svg in a .qrc resource file, it is
> > auto-found, without having to edit anymore code. Let me know if this
> > approach should be used.
> > [0]
> http://drive.dakotacarto.com/qgis/QGIS-images_pre-gis-theme-switch.zip
> > Regards,
> > Larry
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130415/19626112/attachment.html>
