[Qgis-developer] Does Sextante Field Calculator support all functions of attribute table field calc?
Anita Graser
anitagraser at gmx.at
Wed Apr 17 13:42:05 PDT 2013
I have a polygon layer with an "area" field and want to calculate $area /
"area". This works well in attribute table field calculator.
If I try to use Sextante Field Calculator, the resulting field contains
only NULL values. Is this supposed to work? Is this a bug you can confirm?
Best wishes,
Anita
