[Qgis-developer] Possible memory leak in rendering code
Minoru Akagi akaginch at gmail.com
Mon Apr 22 03:03:05 PDT 2013
I found some memory leaks and attached a patch to ticket #6795.
Regards,
Minoru Akagi
2013/4/22 Matthias Kuhn <matthias.kuhn at gmx.ch>:
> Hi Alex,
> I found in the past particularly two things making the rendering more
> stable:
> * Disable Render Cache
> * Enable Backbuffer (only availale in X11/Linux)
> Can you check if one of these two changes in the options fix this issue?
> (Restart after changing)
> Cheers,
> Matthias
> On Mon 22 Apr 2013 10:50:29 CEST, Alexander Bruy wrote:
>> Hi all,
>> working on QTiles plugin we found one odd issue — when number of
>> canvas redraws is relatively big (around 200 000 - 300 000) QGIS
>> crashed with segmentation fault. Seems there is a memory leak
>> somewhere.
>> I'll try to debug this more, but as I'm  not very familiar with rendering code any help and suggestions are welcome. Small test
>> plugin to replicate this issue attached. Also it is possible to use
>> QTiles plugin for this: just set extent and zoom levels so number of
>> tiles is greater that 200 000 and start process. QGIS will crash
>> at 60-70%.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
