[Qgis-developer] behavior of splitting feature
Alexandre Neto senhor.neto at gmail.com
Mon Apr 22 08:14:26 PDT 2013
You can use Multipart Split Plugin to split the selected multipart features.
http://plugins.qgis.org/plugins/splitmultipart/
Alexandre Neto
On Mon, Apr 22, 2013 at 3:07 PM, Denis Rouzaud <denis.rouzaud at gmail.com>wrote:
> Hi,
> I am dealing with multi polygons these days, and I find very annoying to
> not being able to split a part into several part.
> First, am I right saying it's not feasible?
> If yes, I would like to propose to add a choice to the splitting tool:
> - split into several features
> - split into several parts (only availbale for multi-polygon/lines layers)
> Would you agree on this?
> Then, how to propose this to the user?
> 1. Choice dialog after drawing the split lines (propose only if layer has
> multi geometry)
> I think everybody agrees it's a bad option
> 2. Have two icons and two separate tools
> Nice to use, but not to right direction in terms of number of icons in QGIS
> 3. Have a drop down icon as for the selection tool.
> My suggestion.
> If drop-down is the chosen option, I would also suggest to group add part
> with add ring, and also delete part with delete ring. It would therefore
> more coherent.
> Greetings,
> Denis
> ______________________________**_________________
> Qgis-developer mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130422/daac546b/attachment.html>
