[Qgis-developer] Make QGIS interact with LibreCAD.
Andreas Neumann a.neumann at carto.net
Mon Apr 22 12:10:54 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I would prefer if most of the editing tools would be available in core
- - and if possible - implemented in C++.
They could be prototyped in Python and then later moved to core after
maturing.
I hate having to install plugins for simple things, like perpendicular
lines, swapping line direction, extend/trim lines, etc.
Andreas
Am 22.04.2013 17:26, schrieb Antonio Locandro:
> Agreed +1 Having all the needed editing tools in one plugin would
> be better, right now you need to install several plugins to do
> editing work, maybe getting them together under one roof and
> deprecating the original afterwards would make the experience
> easier for users and for writing manuals also
> Ing. Antonio Locandro Tegucigalpa, Honduras +504 9503 5747 Need a
> GPS map for Central America, Asia or South America / Necesitas un
> mapa GPS para Centro America, Asia o Sur America
>> Date: Mon, 22 Apr 2013 17:18:25 +0200 From:
>> cavallini at faunalia.it To: qgis-developer at lists.osgeo.org Subject:
>> Re: [Qgis-developer] Make QGIS interact with LibreCAD.
> Il 22/04/2013 15:17, Diego Gnesi Bartolani ha scritto:
>>>> Stefan and Bernahard, I don't want to create redundancy on
>>>> the plugin repository: if you're working on similar projects,
>>>> maybe I can try to help you instead of starting a brand new
>>>> work.
> Agreed: if at all possible, please join forces rather than
> duplicating plugins: from the user point of view, it can quickly
> become a nightmare to move across hundreds of plugins. Thanks.
>> _______________________________________________ Qgis-developer
>> mailing list Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with undefined - http://www.enigmail.net/
iQEcBAEBAgAGBQJRdYs3AAoJELiCsGDopvBCEpoH+wePjzYJrX+bP088LjviW+eX
6pQHc9a7s+dT6MHN0tSttyPDMiTS/axmci0FmKLK3JQzHQlrGXxh1PZ2/rHSmVBc
WfqjwkgUzEqUa2dge8yqL3yV8inXMd/IJP27hQnBxKocerO62Qo653oOH8pMbIM5
VZ3ZiyHhHBCTaJV17SIPgxMOuaodhz8RQd1h1DCE309uRhMgFzCtg+tm7/q3sr2h
+u8aZ1LmRlfuqoSvfGoks3sjAjVt9HjwVyuR9J/ZIwsi+bBTvZ1961+w8MS2L/yn
BncfqIwwCaW3uxeHZz4Oprse4NslDp8hoMnync2Vd4iNSvQSQoDzGnIJjBKG9N0=
=Tmfz
-----END PGP SIGNATURE-----
