[Qgis-developer] Call for fixes: French and South Africans, raise up
Jürgen E. Fischer jef at norbit.de
Mon Aug 26 03:39:10 PDT 2013
Hi Frank,
On Mon, 26. Aug 2013 at 11:18:50 +0200, Frank Sokolic wrote:
> For the problem with South African CRSs, is this not a simple fix, i.e.  edit
> the proj4 parameters in the srs.db file to remove the +axis=wsu  options from
> all the Lo CRSs? If so, does anyone know how to do it?
How isn't the problem (that should be a simple update statement).
But is that a correct fix?    Are there more people annoyed by the current
entry, than people relying on it?   Is the existing EPSG entry wrong?
Could others from the southern hemisphere comment on that?  Tim?
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
QGIS PSC member (RM)                                   IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
