[Qgis-developer] SLD export problems GraphicFill element
Yewondwossen Assefa assefay at gmail.com
Fri Aug 30 03:10:27 PDT 2013
I had posted on the user list some issues I was having when exporting an
SLD ( http://lists.osgeo.org/pipermail/qgis-user/2013-August/023650.html)
Pocking around the code today, I saw what might be the issue with the
generation of "invalid" sld with graphic fill and a graphic marker:
file qgssymbollayerv2utils.cpp  function  void
QgsSymbolLayerV2Utils::fillToSld (around line 1523) :
    /* Use WellKnownName tag to handle QT brush styles. */
   wellKnownMarkerToSld( doc, graphicFillElem, patternName, fillColor,
borderColor );
  The call to wellKnownMarkerToSld is using the graphicFillElem instead
of the graphicElem
This, as discribe in the previous post produces:
<se:GraphicFill>
  <se:Graphic/>
  <se:Mark>
  </se:Mark>
</se:GraphicFill>
Instead of
<se:GraphicFill>
  <se:Graphic>
    <se:Mark>
   </se:Mark>
  </se:Graphic>
</se:GraphicFill>
Would it be possible for someone to confirm this issue?
regards,
Y. Assefa
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130830/fa5fb71e/attachment-0001.html>
