[Qgis-developer] Console API auto-completion prepared file (.pap)
Salvatore Larosa
lrssvtml at gmail.com
Sat Aug 31 16:32:37 PDT 2013
Hi Larry,
2013/8/31 Larry Shaffer <larrys at dakotacarto.com>
> Hi Salvatore,
> Sorry to keep messing with this, but it was causing a build error. I
> reverted adding of qsci-pap-master target, leaving it similar to as before,
> excepting the convenience target of qsci-pap-src.
> WITH_QSCIAPI is now marked as advanced, to keep casual users from thinking
> they need to regenerate the .pap file as part of building.
> Here is why I think this is the simplest, most versatile solution:
> *Casual user/dev who compiles/installs QGIS*
> Everything works as before with the default pre-prepared pyqgis.pap in
> source tree used. No generation of .pap occurs. PyQGIS.api is still built
> by default and the target for qsci-pap-src is just created.
> *QGIS dev working on bindings*
> Making qsci-pap-src will update the default .pap in source tree, which
> will be used when running from build directory or install during binding
> testing. If the dev is ready to commit, the already-updated .pap includes
> the latest completions, and everyone benefits. We can use git to revert any
> fouled-up .pap that may make its way into the repo. This assumes the
> committing dev actually ran qsci-pap-src. If not, then any other dev can
> easily do so, updating their source tree, then commit the new default .pap.
this I was not clear in my previous email about the update in the source
tree, but now it does make much sense.
No idea for a better solution at the moment, I agree with your solution.
For now we can go ahead keeping your last commit, just after on Sept 1st.
we can think for a better solution (whether it there is) IMO.
Best Regards,
-SL
> I am really done messing with this now. :^) If you have better solution,
> please let me know.
> Regards,
> Larry
> On Sat, Aug 31, 2013 at 12:37 PM, Larry Shaffer <larrys at dakotacarto.com>wrote:
>> Hi Salvatore,
>> On Sat, Aug 31, 2013 at 7:58 AM, Salvatore Larosa <lrssvtml at gmail.com>wrote:
>>> ok Larry, your last commit works fine only I was wonder might be a
>>> problem to edit the source tree file pyqgis.pap by running the qsci-pap-src
>>> target ? just curiosity!
>> I'm not sure I understand your question. Doing periodic updates to the
>> pyqgis.pap in source keeps from forcing everyone who compiles the source to
>> also generate that file. There is no simple means for checking when the API
>> has changed (except maybe SHA comparisons of the API file). Without such a
>> check, the generation of that file may often be unnecessary, but still done.
>> Everyone benefits if that file is kept up to date in the source tree. For
>> example, the one I replaced with the initial commit was 11 months old,
>> missing many completions for new functions.
>> Alternatively, we can set it up similar to what you were suggesting. Let
>> me know what you think would be a better solution.
>> Regards,
>> Larry
>>> Tonight I'll push the updated API files
>>> (GDAL/OGR-1.10.0,QScintilla-2.7.2 and GEOS-3.4.2 ) and will add the
>>> GEOS-3.4.2 APIs to the default .pap file.
>>> Thanks for the clarification !
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130901/e4d57899/attachment.html>
