[Qgis-developer] Video UAV Tracker submitted
Alexandre Neto senhor.neto at gmail.com
Fri Dec 13 16:00:55 PST 2013
Hello Salvatore,
Great plugin, I was hoping to use it to videomaping open street maps.
I was able to make it work with your data, but not with mine. :-(
I keep getting the error below, even after changing my time format
to %Y-%m-%dT%H.%M.%S
Thanks,
Alexandre Neto
An error has occured while executing Python code:
  File
"/home/alex/.qgis2/python/plugins/Video_UAV_Tracker/video_uav_tracker.py",
line 170, in OpenButton
    gpxFile=class_pars.parsfile(str(gpxPath))
  File "/home/alex/.qgis2/python/plugins/Video_UAV_Tracker/pars.py", line
53, in parsfile
    arr_time = time.strptime(arr_time[:-6], '%Y-%m-%dT%H.%M.%S')
  File "/usr/lib/python2.7/_strptime.py", line 454, in _strptime_time
    return _strptime(data_string, format)[0]
  File "/usr/lib/python2.7/_strptime.py", line 325, in _strptime
    (data_string, format))
ValueError: time data '2013-12-08T14.' does not match format
'%Y-%m-%dT%H.%M.%S'
Python version:
2.7.3 (default, Sep 26 2013, 20:13:52)
[GCC 4.6.3]
QGIS version:
2.0.1-Dufour Dufour, exported
Python path: ['/home/alex/.qgis2/python/plugins/processing',
'/usr/share/qgis/python', '/home/alex/.qgis2/python',
'/home/alex/.qgis2/python/plugins', '/usr/share/qgis/python/plugins',
'/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
'/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL',
'/usr/lib/python2.7/dist-packages/gst-0.10',
'/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
'/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
'/usr/lib/python2.7/dist-packages/ubuntuone-client',
'/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
'/usr/lib/python2.7/dist-packages/ubuntuone-couch',
'/usr/lib/python2.7/dist-packages/ubuntuone-installer',
'/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
'/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
'/home/alex/.qgis2/python/plugins/QuickMultiAttributeEdit/forms',
'/usr/share/qgis/python/plugins/fTools/tools']
On Mon, Dec 9, 2013 at 12:24 PM, sagost at katamail.com <sagost at katamail.com>wrote:
>  Hi everybody,
> i've just submitted my plugin to the repository waiting for approval.
> Here there are some data to test it:
> https://www.dropbox.com/s/ugm7awhlwlt5yj3/Dati%20VUT.zip
> Only for let you knows.
> Thans,
> Salvatore
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131214/e4d81664/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131214/e4d81664/attachment-0001.obj>
