[Qgis-developer] Install without admin rights on Windows
Paolo Cavallini cavallini at faunalia.it
Sun Feb 10 23:53:31 PST 2013
Hi all.
Sorry I know little about Windows; I think if possible keeping the possibility of
installing without admin rights would be very good. In many corporate environments
installing as admin requires lots of complications, so the non-admin install proved
an effective tool for QGIS success in these situations.
Has this been changed recently? In case, can this be reverted?
All the best.
-------- Messaggio originale --------
Oggetto: Re: [osgeo4w-dev] [osgeo4w] #339: OSGEO4W Installer doesn't work
Data: Sun, 10 Feb 2013 08:32:42 -0000
Mittente: OSGeo4W <trac_osgeo4w at osgeo.org>
Rispondi-a: osgeo4w-trac at lists.osgeo.org
CC: osgeo4w-trac at lists.osgeo.org
Reporter:  moreno   |       Owner:  osgeo4w-dev@…
    Type:  defect   |      Status:  new
Priority:  blocker  |   Component:  Installer
 Version:           |    Keywords:  Installer OSGEO4W
Comment(by hellik):
 Replying to [comment:9 lpinner]:
 > Non-elevated behaviour is a result of this ticket
 -http://trac.osgeo.org/osgeo4w/ticket/304 which likely causes permissions
 issues when not run as Admin on an existing OSGeo4W install where all
 files would require Admin privileges to modify.
 thanks for the hint.
 I suggest some short note about this somewhere in website/wiki/trac and
 then to close the ticket.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/339#comment:10>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
osgeo4w-dev mailing list
osgeo4w-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
