[Qgis-developer] Several errors
Sanghee Shin endofcap at gmail.com
Tue Feb 12 20:02:36 PST 2013
I run crssync manually and I found that crssync tried to update srs.db in wrong path. So for my testing,  I created folder and put the srs.db there and re-run the crssync. Finally I got the updated srs.db successfully. Wow!
I think it's not the problem or bug of crssync but the problem of post-installation process in master version.
I'll test more.
Thanks.
Sanghee
Windows :
Synchronizing CRS database with GDAL/PROJ definitions.
Could not open database: C:/Programme/OSGeo4W/apps/qgis-dev/./resources/srs.db [unable to open database file]
Mac OSX :
Could not open database: /Users/larrys/QGIS/nightly/QGIS_Apps/QGIS_2.0-dev.app/Contents/MacOS/../Resources/resources/srs.db [unable to open database file]
2013. 2. 13., 오전 3:27, Andre Joost <andre+joost at nurfuerspam.de> 작성:
> Am 12.02.2013 18:53, schrieb Sanghee Shin:
>> Hi,
>> I updated my ticket and also attached setup.log.full there for your digging.
> Looks like a QT dll version problem:
> <http://stackoverflow.com/questions/11293337/qt-exited-with-code-1073741511>
> http://www.qtcentre.org/threads/26213-exited-with-code-1073741511
> http://www.qtcentre.org/threads/26604-Runtime-problem-in-Release-mode
> Do you have any other version of QT on your system, which brings a false dll into the Windows path?
>> I just wonder whether there is any similar post-installation log file in Mac OSX and Ubuntu.
> Sorry, not my world ;-)
> Greetings,
> André Joost
> Qgis-developer mailing list
