[Qgis-developer] Composer item's IDs
Nathan Woodrow madmanwoo at gmail.com
Mon Feb 18 16:04:08 PST 2013
Thinking about this. There really isn't a reason to force item names/id to
be unqiue . if I want to have three items named the same then that is
really my choice.  If I have say three map windows that I want to set all
to the same extents then I could just call them all "maps" and just loop
over all the items with that name.
- sent from a tablet device that isn't an iPad
On 19 Feb 2013 10:54, "Nathan Woodrow" <madmanwoo at gmail.com> wrote:
> Personally I'm not a fan of using a uuid unless the user doesn't need to
> enter them.
> For me a composer item only needs a id or name not both.  You can just
> store a counter on the composer the item belongs to as only has to be
> unique for that composer. I would just auto name them "composeritem_n" and
> have the composer assign the name/id when the item is added to the
> composer. If the user wants to change it later he can.
> On 19 Feb 2013 10:38, "Olivier Dalang" <olivier.dalang at gmail.com> wrote:
>> OK I've got something which seems to work well using QUuid.
>> It's easier with QUuid than an incremental id since there's no need to
>> store the last key.
>> It already works more or less, I'll make a pull request soon.
>> What do you think about the other attribute ? (which would be called
>> smthg like "Internal name", and would replace current id's behavior)
>> I'm not sure this is useful though. Maybe it will only be confusing to
>> the user...
>> Should I add this attribute or not ?
>> 2013/2/18 Nathan Woodrow <madmanwoo at gmail.com>:
>> > Olivier,
>> > I added the item id for that reason. Feel free to rework then so they
>> > are auto generated and unique. That was my intention just never got
>> > around to it.
>> > - Nathan
>> > Sent from some fancy phone looking thingo
>> > From: Olivier Dalang
>> > Sent: 19/02/2013 3:27 AM
>> > To: qgis-developer at lists.osgeo.org
>> > Subject: [Qgis-developer] Composer item's IDs
>> > Hi !
>> > I'm developing a plugin which needs to attach some custom data to some
>> > Composer Item's instances.
>> > Thus, I need a way to identify the instances.
>> > I saw that there's an ID attribute in the ComposerItems, but don't
>> > really know how it's supposed to work. It seems for now it's only an
>> > user defined value, which remains empty when the user doesn't provide
>> > it and which also can be duplicated.
>> > So it seems I can't use this as an unique ID.
>> > What's the best way to do that ?
>> > More globally, what is this ID good for ? Is it's behavior not fully
>> > implemented yet ?
>> > I think it would be useful to auto-assign unique which the user
>> > couldn't change. If needed, another attribute ("name" or "tag") could
>> > be added to replace the current "ID" behaviour, allowing the user to
>> > define custom data.
>> > What do you think ?
>> > Thanks !!
>> > Olivier
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130219/623a9c9b/attachment-0001.html>
