[Qgis-developer] Shipping SAGA with QGIS
Tim Sutton lists at linfiniti.com
Sun Feb 24 05:32:29 PST 2013
Hi
On Sun, Feb 24, 2013 at 3:11 PM, Victor Olaya <volayaf at gmail.com> wrote:
> Phil
> Thanks for you help. Unfortunately, I do not use Mac and cannot test
> SEXTANTE in Mac.
> The psycopg library is used by algorithms connecting with PostGIS, and
> I (wrongly) assumed it should be in all computers where QGIS is
> installed. I will add some checking to ensure that it is found and, if
> not, disable the corresponding algorithms but not the whole SEXTANTE
> plugin
> Regarding the error you see when executing SAGA, In Mac it is
> performing the same check than in Linux, but it seems that it is not
> working fine, even if SAGA is actually installed. Making SEXTANTE run
> a small test algorithm and check the result sounds like a better
> option, which would work for all OS's
> Thanks again for your help.
> Victor
> 2013/2/23 Phil Hess <macpgmr at fastermac.net>:
>>>>I tried installing SEXTANTE just now on a Mac but it crashed with a missing
>> "psycopg2" error message.
>>>>This is not a standard Python package on Mac.
>> I see now that psycopg2 is also provided as a Mac package here:
>> http://www.kyngchaos.com/software/python
>> Installing Psycopg2-2.4.5-2.dmg allows the SEXTANTE installation to complete
>> successfully.
>> However, SEXTANTE doesn't seem to know about my SAGA:
>> "It seems that SAGA is not correctly installed in your system.
>> Please install it before running SAGA algorithms."
>> Thanks.
>> -Phil
>> View this message in context: http://osgeo-org.1560.n6.nabble.com/Shipping-SAGA-with-QGIS-tp5036274p5036389.html
>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
I would be very much in favour of shipping SAGA bundled in with the
OSX and Windows standalone installers. It creates a much better 'out
of the box' experience and works better in environments where there is
little / no internet available.
Regards
Tim
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
