[Qgis-developer] Shipping SAGA with QGIS
Victor Olaya volayaf at gmail.com
Mon Feb 25 11:19:42 PST 2013
> Note that some of the saga_cmd commands may have changed. For example, SAGA
> Wetness Index now has several new params and the old "t" param is gone.
The current definitions are ok for saga 2.0.8.
Once 2.1 is out, I think a review of all of them should be made.
Hopefully, by that time we will have unit tests for all algorithms,
and we will be able to check that automatically
> What would you like run and sent to you?
Just any SAGA algorithm, to see how it is executed in the command
line. A valid command line that, if run in a batch file created by
SEXTANTE, would execute SAGA correctly
If there is no need to set any variable, how do I use the config path
entered by the user? As I said, I think it is OK to keep than config
parameter as in the Windows version, but with that prepared package,
maybe better to go for the unix-like configuration and assume SAGA it
is already in PATH? In windows, PATH is changed before executing the
batch file.
Sorry for my ignorance about Mac :-)
Thanks again!
Cheers
Victor
