[Qgis-developer] Test dataset for SEXTANTE unit tests?
Victor Olaya volayaf at gmail.com
Thu Feb 28 14:06:32 PST 2013
hi all
I am trying to make it easier to generate unit tests for SEXTANTE
algorithms, so this task can even be outsourced to non-programmers.
The idea is that, having an example dataset, an user should be able to
run an algorithm and then check if the results are as expected. If so,
SEXTANTE would generate the corresponding code for a test checking
exactly that, and we could add that to a test suite.
I would like to know if  someone knows about any good and small
dataset that is available to be used for that, to avoid having to
create it. It should be some synthetic dataset dat covers all test
cases that might appear.
Thanks in advance
Victor
