[Qgis-developer] QgsColorButton
Martin Dobias wonder.sk at gmail.com
Mon Jan 7 08:29:21 PST 2013
On Mon, Jan 7, 2013 at 5:15 PM, Werner Macho <werner.macho at gmail.com> wrote:
> OK - Then I was wrong with my guess .. :)
> @Martin .. is V2 a better implementation or is it ok to stick with the
> original code? Just because most people prefer to use the original code does
> not mean that they should not use V2 if it is better ..
>  But I see you already voted for removing V2
No, in this case V2 is not better, it's just different :-)
> anyway - what about implementation into the Widget?
Automatic handling of the button click (+signal for color change) may
be useful. But prior to changing that I would suggest looking at the
code to see if we need to handle some special cases. For example, I
think for some color dialogs we use ShowAlphaChannel option for
QColorDialog.
Martin
