[Qgis-developer] Contour plugin (Official QGIS repository) failure
G.T.C.vandenBerg gtcvandenberg at gmail.com
Tue Jan 8 03:56:27 PST 2013
Hello,
I had planned to use the QGIS-plugin 'Contour' from the Official QGIS repo
to create a contourline-shapefile from a point-shapefile. My point-shapefile
has 1 column ('z') in which represents the altitude of the points. However,
when I click the plugin-button I get the following message:
"Failure while executing Pyton code:
File "/home/guus/.qgis//python/plugins/contour/contour.py", line 266, in
uFieldNameUpdate
x, y, z = self.getData(self._layer, inputField)
File "/home/guus/.qgis//python/plugins/contour/contour.py", line 590, in
getData
z = map(float, z) #TODO : take care of NaNs, NULL, "",...
ValueError: could not convert string to float:
Python version:
2.7.3 (default, Aug 1 2012, 05:25:23)
[GCC 4.6.3]
QGIS version:
1.8.0-Lisboa Lisboa, exported"
And when I close this message, I get another one:
File "/home/guus/.qgis//python/plugins/contour/contour.py", line 70, in run
dlg = ContourDialog(self._iface)
File "/home/guus/.qgis//python/plugins/contour/contour.py", line 145, in
__init__
if self._isMPLOk() == False:
File "/home/guus/.qgis//python/plugins/contour/contour.py", line 177, in
_isMPLOk
version = [int(i) for i in mpl.__version__.split('.')]
ValueError: invalid literal for int() with base 10: '1rc'
Python version:
[GCC 4.6.3]
QGIS version:
Does anybody have an idea what goes wrong? It's clearly not my
point-shapefile, as the failure-message appears before I'm able to select
anything.
Regards,
Guus van den Berg
View this message in context: http://osgeo-org.1560.n6.nabble.com/Contour-plugin-Official-QGIS-repository-failure-tp5026137.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
