[Qgis-developer] Further improvements of the atlas serial printing
Andreas Neumann a.neumann at carto.net
Fri Jan 25 08:18:08 PST 2013
 Dear QGIS users,
 We will be financing two improvements in the atlas serial printing
 functions of the print composer:
 * ability to order the pages in the multipage PDF based on an attribute
 column and sort order
 * ability to filter the set of pages (e.g. only print pages for
 features with ID 4,6,8) based on an expression
 The work will be done by Oslandia, the ones who originally worked on
 Atlas serial printing. I just wanted to let you know that someone is
 working on it.
 The other reason I am contacting you is that I have additional wishes
 and ideas for serial printing and reporting which I can't finance now.
 One is:
 * ability to supply a list of desired map scales and grid spaces for
 the mapgrid - Atlas would pick the one scale from the list where the
 feature fully fits in. E.g. one would supply the following mapscales:
 1000,2000,2500,5000,7500,10000,12500,15000,2000,25000 and grid spaces:
 25,30,50,75,100,...
 There is already a list of map scales in the project settings. Maybe we
 can enhance it with corresponding grid spaces.
 Would someone have an interest in financing this feature? If yes,
 please contact me.
 Further along I want to see QGIS morph into a reporting tool (similar
 to Jasper) where one could also print data sheets with photos, tables,
 charts, etc. - but directly from QGIS - and also available through QGIS
 server through extended GetPrint commands.
 Maybe something to discuss in Valmiera at the hackfest.
 Best greetings,
 Andreas
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
