[Qgis-developer] qgis-webclient - sample data > 200M
Tim Sutton lists at linfiniti.com
Wed Jul 10 03:50:45 PDT 2013
Hi
I know gh recently reduced their maximum hosted file size - see
https://help.github.com/articles/working-with-large-files
Regards
Tim
On Wed, Jul 10, 2013 at 12:30 PM, Otto Dassau <dassau at gbd-consult.de> wrote:
> Hi Andreas,
> for 50M to 100M you get a warning, but the HYP_50M_SR_W.tif is 166.94 MB
> and
> that's too much. For both files I resampled output files from 0.03 to 0.08
> degree
> pixel resolution. That is 4500 x 2250 instead of 10800, 5400 pixel. Still
> sufficient I think.
> Both would now be below 50M of size. Is that ok? Then I would commit the
> changes.
> Regards
> Otto
> Am Wed, 10 Jul 2013 12:09:47 +0200 schrieb Andreas Neumann
> <a.neumann at carto.net>:
> > Hi Otto,
> > Thank you for pointing this out. Isn't this just a warning?
> > If you have a good test project with smaller data to share I am happy to
> > replace it with a smaller project.
> > I just did not have the time to work on the sample project.
> > Anyway - the file could be checked out by hand or it can just be ignored.
> > Andreas
> > Am 10.07.2013 11:49, schrieb Otto Dassau:
> > > Hi,
> > > I just wanted to update my fork of the qgis-web-client from master and
> > > found following error message:
> > > Total 64 (delta 45), reused 0 (delta 0)
> > > remote: Error code: 5e0226a6eeb7f2d80768c4e7996297dc
> > > remote: warning: Error GH413: Large files detected.
> > > remote: warning: See http://git.io/iEPt8g for more information.
> > > remote: warning: File data/SR_50M.tif is 55.70 MB; this is larger than
> > > GitHub's recommended maximum file size of 50 MB remote: error: File
> > > data/HYP_50M_SR_W.tif is 166.94 MB; this exceeds GitHub's file size
> > > limit of 100 MB
> > > Can I tell github to change the accepted file size or would it be
> > > possible to use smaller test data?
> > > 167M - HYP_50M_SR_W.tif
> > > 56M  - SR_50M.tif
> > > Regards
> > > Otto
> > > _______________________________________________
> > > Qgis-developer mailing list
> > > Qgis-developer at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Geoinformatik Büro Dassau - http://www.gbd-consult.de
> FOSSGIS consulting , training , support  and analysis
> Ackerstrasse 144c  ,  D - 40233 Düsseldorf  , Germany
> Tel: +49-(0)211-47468178 , Mobil: +49-(0)171-4687540
> Community Advisor - QGIS Project Steering Committee
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130710/3e6e8cd3/attachment.html>
