[Qgis-developer] map rendering time much longer on windows than on ubuntu
Denis Rouzaud denis.rouzaud at gmail.com
Wed Jul 10 05:58:32 PDT 2013
Hi Jürgen,
Effectively, I noticed the postgres difference from the command line, so
nothing related to QGIS...I'll try to investigate the question with our IT .
The problem is that QGIS is almost unusable in these conditions, with
rendering time of about 2s!
Is there an easy way to produce a windows installer? By easy I mean from
my compilation environment on ubuntu? Or do I need to compile on Windows?
Thanks,
Denis
On 07/10/2013 10:19 AM, Jürgen E. Fischer wrote:
> Hi Denis,
> On Wed, 10. Jul 2013 at 09:52:33 +0200, Denis Rouzaud wrote:
>> Also, I'd like to try to remove the debug info.
>> Is the correct way to do this: in environment variables: add a
>> QGIS_DEBUG variable with -1 value in the user variables?
> That would still produce the output, but not show it.  Not sure if the pure
> production alone also has a noticable impact.
> But the production of the output doesn't really explain, why the same requests
> are sometimes slower.  Maybe looking at the output would help here ;)
> Otherwise getting rid of debugging output completely would require a Release
> build (which would not include -DQGISDEBUG).
> Jürgen
