[Qgis-developer] Mac nightlies updated
Larry Shaffer larrys at dakotacarto.com
Sun Jul 14 18:26:40 PDT 2013
Hi Royce,
On Sun, Jul 14, 2013 at 3:52 PM, Cline, Royce L. <rcline at nd.gov> wrote:
> William
> Juergen's fix from Friday of the problem loading empty tables and his fix
> from yesterday so that DB Manger now recognizes SpatiaLite version 4
> metadata tables both work. Tested with Larry's nightly build from this
> morning. I can now create a new layer for editing and drag and in DB
> Manager dropping tables into either SpatiaLite version 3 or 4 databases
> works very well.
I can confirm this works for my local builds as well (10.7.5). Spatialite 4
now seems to be mostly, if not completely, functional now. Thank you,
Juergen!
> Since Larry is requesting features, I have one. It would be very useful to
> anybody on OS X that does much with SpatiaLite to have Spatialite_GUI
> available from your site. Would it take much additional effort to also
> build this when you build spatialite?
I, too, work with spatialite_gui as it is (I think) the best means for
working with spatialite dbs/tables. Unfortunately, it's gui is built off of
wxWidgets instead of Qt, i.e. an additional gui toolkit would need to be
installed with or alongside William's frameworks. However there is an easy
means of getting the latest versions of those, by using homebrew in an
isolated install directory [0].
[0] http://drive.dakotacarto.com/qgis/spatialite-gui_homebrew-install.txt
Regards,
Larry
> Royce
> On Jul 14, 2013, at 3:55 PM, William Kyngesburye <woklist at kyngchaos.com>
> wrote:
> > On Jul 14, 2013, at 3:21 PM, Larry Shaffer wrote:
> >> Hi William,
> >> On Thu, Jul 11, 2013 at 9:28 PM, William Kyngesburye <
> woklist at kyngchaos.com> wrote:
> >> On Jul 11, 2013, at 9:32 PM, Larry Shaffer wrote:
> >>> William, the issues with Spatialite 4.0.0 still persist [1]. Maybe
> having your SQLite framework updated to Spatialite 4.1.1 before trying to
> track down those errors might be prudent?
> >>> [0] http://qgis.dakotacarto.com
> >>> [1] http://hub.qgis.org/issues/7664
> >> I don't see any compatibility-breaking changes (would require new
> framework version and rebuild of everything), so I'll work on it over the
> weekend.
> > Have you tried QGIS yet with Juergen's change to accept empty spatialite
> DBs?  It would be good to check if this works before trying Spatialite 4.1.
> >> Another nice addition to spatialite would be to add the liblwgeom
> support. This is part of the postgis build, but can have its .so and
> headers files moved to a different location (I believe) because it only
> links to libgeos_c and libproj. However, I did not find
> liblwgeom-2.0.3.dylib in your install for postgis 2.0.3.
> >> Since the .dylib can be included standalone (after postgis is built)
> and spatialite built against that, could you include liblwgeom in your
> SQLite3 framework (or maybe GEOS framework)? This would offer extra
> geometry functions to spatialite [0] (especially the MakeValid function)
> without requiring users to install the full postgres/postgis package.
> > Maybe.  It's getting messy.  But, PostGIS is GPL, and I'd rather keep
> the whole framework non-GPL.  So it would have to be the standard full
> Postgres+PostGIS install, but then the framework becomes dependent on
> PostGIS (directly) and Postgres (indirectly).
> >> Also, having worked with recent spatialite builds for the homebrew
> project, I came across the nice additional XML functions for spatialite
> [1]. I did not have issues building libspatialite against default libxml2
> on Lion (10.7.5), but spatialite-gui failed unless I built libspatialite
> against a newer 2.9.x version of libxml2 [2]. 2.9.x version is recommended
> (required?) for spatialite.
> >> The xml functions could be used for the proposed QGIS project-as-db
> setup, where the current project xml-formatted file could be directly
> stored in a spatialite db, with minimal adjustment to existing project
> reading/writing code.
> > I saw this addition to 4.1 and expect to build it in.  Looks like Mt
> Lion also has xml2 2.7.  Another messy addition if using xml2 2.9, but
> license is OK.
> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> > http://www.kyngchaos.com/
> > "This is a question about the past, is it? ... How can I tell that the
> past isn't a fiction designed to account for the discrepancy between my
> immediate physical sensations and my state of mind?"
> > - The Ruler of the Universe
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130714/b7706836/attachment-0001.html>
