[Qgis-developer] Labels on topologically wrong polygons
Larry Shaffer larrys at dakotacarto.com
Wed Jul 24 11:55:41 PDT 2013
Hi Paolo,
On Wed, Jul 24, 2013 at 10:25 AM, Paolo Cavallini <cavallini at faunalia.it>wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Il 24/07/2013 18:21, Larry Shaffer ha scritto:
> >> But that just wraps the C++ library with Python doesn't? (Very nice,
> btw!) That still
> >> requires a full install of PostGIS/PostgreSQL (at this time):
> not, we have compiled it as standalone; in deb it is the same:
> http://packages.debian.org/sid/liblwgeom-2.0.3
> >> For labeling, I don't think we would want to introduce Python into the
> mix, or
> >> require PostGIS to be installed. So, either C++ compiled-in or shared
> lib support
> >> would be best (for the speed).
> agreed
> >> Do you have some links to any notes on how this was done using the
> PostGIS source
> >> code? I'd like to make that library available for the Mac builds and
> pass the notes
> >> along to others.
> coming soon
Actually, I hadn't tested building the standalone Mac liblwgeom.dylib since
PostGIS 2.0.3 came out. I was able to easily build the .dylib for both
2.0.3 and with current source trunk. Trunk appears to now require the
json-c lib, which was not part of the Kyngchaos framework installs, but is
readily available via homebrew.
So, it fairly simple to compile and include liblwgeom-2.0.3.dylib (422 KB)
with Mac bundled app builds, once it is utilized directly in QGIS code.
Very nice, indeed, for geometry repairing routines!
William, here is what I did [0]. Please let me know if there is something I
am missing in the build steps that might cause issues for use in a bundled
QGIS. Thanks.
[0] http://drive.dakotacarto.com/qgis/liblwgeom.dylib-build.txt
Regards,
Larry
> thanks.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.12 (GNU/Linux)
> Comment: Using GnuPG with Icedove - http://www.enigmail.net/
> iEYEARECAAYFAlHv//sACgkQ/NedwLUzIr4Y9wCfZm9hqdp2EcnBVShAbleg0DpW
> tMYAnR6S/thBQW/9XfWQekRZPAF2wYNZ
> =BSK3
> -----END PGP SIGNATURE-----
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130724/691e8411/attachment.html>
