[Qgis-developer] the new Plugin Manager
Nathan Woodrow madmanwoo at gmail.com
Tue Jun 4 23:53:27 PDT 2013
Marco,
As Borys is away would you be able to merge it tonight.  I can then merge
the SIP update once that is done, just need to check the status.  I'll take
care of updating the python part of the installer to the new API once it's
merged into master.
Regards,
Nathan
On Wed, Jun 5, 2013 at 4:48 PM, Marco Hugentobler <
marco.hugentobler at sourcepole.ch> wrote:
> Hi Borys
> I tested the newpluginmanager branch and I must say the new plugin manager
> / installer is really a great user experience. And it is good that the
> plugin manager also works without the python bindings (handy e.g. in the
> server case).
> Codewise, I have few suggestion on detail level:
> QgsPluginRegistry: isLoaded(), isPythonPlugin(), isPluginCompatible() can
> be const
> QgsPluginManager: pluginMetadata() returns a pointer to the map. This
> function should be const and return either const pointer or a copy (kind of
> similar issue like recently with the layer registry)
> It might be worth thinking if QgsPluginRegistry should be in core and
> accessible by third party apps / plugins. Like that it would e.g. be
> possible to use functions from one plugin in another and load the required
> plugin if not already there. The plugin registry could also emit an unload
> signal to notify the dependent plugin. I'm not 100% sure it is a good idea,
> but maybe it would be handy for sextante (e.g. WPS plugin requires a loaded
> sextante)?
> All in all great work. I'm proposing that you merge the branch to master.
> Regards,
> Marco
> On 27.05.2013 14:23, Borys Jurgiel wrote:
>> Hi All,
>> The new manager is ready. Here is a screenshot for impatient ones :)
>> http://tmp.borysjurgiel.pl/**manager4.png<http://tmp.borysjurgiel.pl/manager4.png>
>> The code is in a branch "newmanager":
>> http://hub.qgis.org/projects/**quantum-gis/repository/**revisions/**
>> 5ee09d362148c411047a0fc7bc2267**9d9989f771<http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771>
>> As it affects a number of classes, please review the architecture summary
>> below and if there is no veto, it's ready to be merged to master.
>> Otherewise I'll
>> make requested changes before merging.
>> *QgsPluginItem*
>> Removed. It only used in the old manager and wasn't usefull anymore.
>> *QgsDetailedItemData, QgsDetailedItemDelegate and QgsDetailedItemWidget*
>> Untouched. It was used in the old manager and Grass Plugin, now it's used
>> exclusively by Grass Plugin.
>> *QgsPluginMedatadata*
>> Untouched, however I propose to rename it to QgsPluginItem or
>> QgsPluginRegistryItem
>> for consistency. It's only used in QgsPluginRegistry and it mainly
>> conatains
>> pointers to loaded plugins instances, while its name may imply a rich
>> metadata
>> map. If some day during QGIS 2.x lifetime the Manager will need a
>> separate class
>> for storing rich metadata (now QMap is enough), and it would be nice to
>> use this name.
>> *QgsPluginRegistry*
>> Info: This class is a registry for instances of lodaded plugins. It has
>> nothing to to
>> with metadata and it works independently from the manager, just by
>> restoring
>> session plugins from QSettings. Manager only calls its method to load and
>> unload plugins.
>> Small change: as it already had methods loadCppPlugin() and
>> loadPythonPlugin(),
>> I've added also unloadCppPlugin() and unloadPythonPlugin() too keep the
>> loading/unloading stuff in one place.
>> Diff:
>> 5ee09d362148c411047a0fc7bc2267**9d9989f771/diff/src/app/**
>> qgspluginregistry.h<http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgspluginregistry.h>
>> qgspluginregistry.cpp<http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgspluginregistry.cpp>
>> *QgsPluginManager*
>> Completely rewritten and moved to src/app/pluginmanager/ subdirectory
>> class for the dialog window. Important facts:
>> 1) It keeps plugin metadata registry just in nested QMap:
>> QMap< QString, QMap<QString,QString> >   mPlugins;
>> where the first key is library/module basename, and the second one is
>> attribute
>> name. There was no need to create a separate class for storing metadata,
>> however, some day it may become convinient to create a class called
>> QgsPluginMedatadata.
>> For this reason I propose to rename the current QgsPluginMedatadata
>> (what actually has nothing to do with metadata) before releasing QGIS 2.0.
>> The list of used attributes is provided in the "metadata" file and it's
>> an unification
>> of existing fields from repository xml, metadata.txt, the old installer
>> and c++ plugins.
>> QgsPluginManager populates this field (let's call it metadata registry)
>> with
>> c++ plugins when the window is opened. On the contrary, Python plugins
>> are handled on Python's side and they are appended to mPlugins by API.
>> 2) The plugin list view uses QStandardItemModel populated from mPlugins
>> and also QgsPluginSortFilterProxyModel for filtering and sorting.
>> 3) The html metadata browser is quite simple, and we can extend it in
>> QGIS 2.1.
>> For example, some tags can be clickable and set a new filter (filter by
>> clicked
>> author/tag/status). Also the separate buttons Install/Uninstall can be
>> implemented by html "buttonsm", and the popup dialog with installation
>> progress
>> can be replaced by animated image (this way we don't freeze the gui when
>> installing).
>> Code:
>> 5ee09d362148c411047a0fc7bc2267**9d9989f771/entry/src/app/**pluginmanager/
>> **qgspluginmanager.h<http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginmanager.h>
>> **qgspluginmanager.cpp<http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginmanager.cpp>
>> ***QgsPluginSortFilterProxyModel*
>> New class: just a sort-filter proxy for the metadata. Filtering is done
>> by status
>> in the left list as well as name/description/tags/author in the filter
>> input line.
>> Sorting is done by rightclicking on the list. Foltering and sorting is
>> based
>> on a few user data roles. I tried to read necessary data from mPlugins
>> everytime,
>> but it affected the performance too much.
>> Code:
>> **qgspluginsortfilterproxymodel.**h<http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginsortfilterproxymodel.h>
>> **qgspluginsortfilterproxymodel.**cpp<http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginsortfilterproxymodel.cpp>
>> *QgsAppPluginManagerInterface, QgsPluginManagerInterface and SIP binding*
>> New classes: just the interface to QgsPluginManager. Is's exactly based
>> on the existing Qgs(App)LegendInterface
>> Code:
>> 5ee09d362148c411047a0fc7bc2267**9d9989f771/entry/python/gui/**
>> qgspluginmanagerinterface.sip<http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/python/gui/qgspluginmanagerinterface.sip>
>> 5ee09d362148c411047a0fc7bc2267**9d9989f771/entry/src/gui/**
>> qgspluginmanagerinterface.h<http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/gui/qgspluginmanagerinterface.h>
>> qgspluginmanagerinterface.cpp<http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/gui/qgspluginmanagerinterface.cpp>
>> **qgsapppluginmanagerinterface.h<http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgsapppluginmanagerinterface.h>
>> **qgsapppluginmanagerinterface.**cpp<http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgsapppluginmanagerinterface.cpp>
>> QgisApp
>> Small change: initialize the QgsPluginManager and Python module
>> pyplugin_installer in the constructor. Only open the QgsPluginManager
>> window
>> when called from the main menu.
>> Diff:
>> 5ee09d362148c411047a0fc7bc2267**9d9989f771/diff/src/app/**qgisapp.h<http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisapp.h>
>> 5ee09d362148c411047a0fc7bc2267**9d9989f771/diff/src/app/**qgisapp.cpp<http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisapp.cpp>
>> QgisAppInterface and QgisInterface and SIP binding
>> Small change: instantiate Qgs(App)PluginManagerInterface
>> exactly the same way as Qgs(App)LegendInterface
>> Diff:
>> qgisappinterface.h<http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisappinterface.h>
>> qgisappinterface.cpp<http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisappinterface.cpp>
>> pyplugin_installer Python module
>> New python module in python/pyplugin_installer. It contains just slightly
>> refactored
>> code of the old plugin_installer plugin and provides backend for handling
>> Python
>> plugis, e.g.: fetching remote repositories, loading installed plugin
>> metadata, finding
>> upgradeable plugins, (un)installing python plugins etc. It's methods are
>> called from
>> QgsPluginManager and it calls QgsPluginManager methods via
>> QgsPluginManagerInterface.
>> Code:
>> 5ee09d362148c411047a0fc7bc2267**9d9989f771/show/python/**
>> pyplugin_installer<http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/show/python/pyplugin_installer>
>> ______________________________**_________________
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Dr. Marco Hugentobler
> Sourcepole -  Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.**ch <marco.hugentobler at sourcepole.ch>
> http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130605/56ef6efe/attachment-0001.html>
