[Qgis-developer] the new Plugin Manager
Marco Hugentobler marco.hugentobler at sourcepole.ch
Wed Jun 5 00:15:37 PDT 2013
 >I can merge the new plugin installer tonight if your happy with that
Perfect, thanks.
Marco
On 05.06.2013 09:12, Nathan Woodrow wrote:
> Marco,
> I can merge the new plugin installer tonight if your happy with that.
>  I'm not sure I will merge the SIP stuff in just yet but I will review
> and see where to go from there.
> Regards,
> Nathan
> On Wed, Jun 5, 2013 at 5:09 PM, Marco Hugentobler
> <marco.hugentobler at sourcepole.ch
> <mailto:marco.hugentobler at sourcepole.ch>> wrote:
>     Hi Nathan
>     I'm away today and can merge earliest late evening or probably in
>     the morning.
>     Alternatively, to not block your progress with the new API, you
>     could do the plugin manager merge / SIP update / python part
>     update and the const things can be easily added later.
>     Regards,
>     Marco
>     On 05.06.2013 08:53, Nathan Woodrow wrote:
>>     Marco,
>>     As Borys is away would you be able to merge it tonight.  I can
>>     then merge the SIP update once that is done, just need to check
>>     the status.  I'll take care of updating the python part of the
>>     installer to the new API once it's merged into master.
>>     Regards,
>>     Nathan
>>     On Wed, Jun 5, 2013 at 4:48 PM, Marco Hugentobler
>>         Hi Borys
>>         I tested the newpluginmanager branch and I must say the new
>>         plugin manager / installer is really a great user experience.
>>         And it is good that the plugin manager also works without the
>>         python bindings (handy e.g. in the server case).
>>         Codewise, I have few suggestion on detail level:
>>         QgsPluginRegistry: isLoaded(), isPythonPlugin(),
>>         isPluginCompatible() can be const
>>         QgsPluginManager: pluginMetadata() returns a pointer to the
>>         map. This function should be const and return either const
>>         pointer or a copy (kind of similar issue like recently with
>>         the layer registry)
>>         It might be worth thinking if QgsPluginRegistry should be in
>>         core and accessible by third party apps / plugins. Like that
>>         it would e.g. be possible to use functions from one plugin in
>>         another and load the required plugin if not already there.
>>         The plugin registry could also emit an unload signal to
>>         notify the dependent plugin. I'm not 100% sure it is a good
>>         idea, but maybe it would be handy for sextante (e.g. WPS
>>         plugin requires a loaded sextante)?
>>         All in all great work. I'm proposing that you merge the
>>         branch to master.
>>         Regards,
>>         Marco
>>         On 27.05.2013 14:23, Borys Jurgiel wrote:
>>             Hi All,
>>             The new manager is ready. Here is a screenshot for
>>             impatient ones :)
>>             http://tmp.borysjurgiel.pl/manager4.png
>>             The code is in a branch "newmanager":
>>             http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771
>>             As it affects a number of classes, please review the
>>             architecture summary
>>             below and if there is no veto, it's ready to be merged to
>>             master. Otherewise I'll
>>             make requested changes before merging.
>>             *QgsPluginItem*
>>             Removed. It only used in the old manager and wasn't
>>             usefull anymore.
>>             *QgsDetailedItemData, QgsDetailedItemDelegate and
>>             QgsDetailedItemWidget*
>>             Untouched. It was used in the old manager and Grass
>>             Plugin, now it's used
>>             exclusively by Grass Plugin.
>>             *QgsPluginMedatadata*
>>             Untouched, however I propose to rename it to
>>             QgsPluginItem or QgsPluginRegistryItem
>>             for consistency. It's only used in QgsPluginRegistry and
>>             it mainly conatains
>>             pointers to loaded plugins instances, while its name may
>>             imply a rich metadata
>>             map. If some day during QGIS 2.x lifetime the Manager
>>             will need a separate class
>>             for storing rich metadata (now QMap is enough), and it
>>             would be nice to use this name.
>>             *QgsPluginRegistry*
>>             Info: This class is a registry for instances of lodaded
>>             plugins. It has nothing to to
>>             with metadata and it works independently from the
>>             manager, just by restoring
>>             session plugins from QSettings. Manager only calls its
>>             method to load and unload plugins.
>>             Small change: as it already had methods loadCppPlugin()
>>             and loadPythonPlugin(),
>>             I've added also unloadCppPlugin() and
>>             unloadPythonPlugin() too keep the
>>             loading/unloading stuff in one place.
>>             Diff:
>>             http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgspluginregistry.h
>>             http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgspluginregistry.cpp
>>             *QgsPluginManager*
>>             Completely rewritten and moved to src/app/pluginmanager/
>>             subdirectory
>>             class for the dialog window. Important facts:
>>             1) It keeps plugin metadata registry just in nested QMap:
>>             QMap< QString, QMap<QString,QString> > mPlugins;
>>             where the first key is library/module basename, and the
>>             second one is attribute
>>             name. There was no need to create a separate class for
>>             storing metadata,
>>             however, some day it may become convinient to create a
>>             class called QgsPluginMedatadata.
>>             For this reason I propose to rename the current
>>             QgsPluginMedatadata
>>             (what actually has nothing to do with metadata) before
>>             releasing QGIS 2.0.
>>             The list of used attributes is provided in the "metadata"
>>             file and it's an unification
>>             of existing fields from repository xml, metadata.txt, the
>>             old installer and c++ plugins.
>>             QgsPluginManager populates this field (let's call it
>>             metadata registry) with
>>             c++ plugins when the window is opened. On the contrary,
>>             Python plugins
>>             are handled on Python's side and they are appended to
>>             mPlugins by API.
>>             2) The plugin list view uses QStandardItemModel populated
>>             from mPlugins
>>             and also QgsPluginSortFilterProxyModel for filtering and
>>             sorting.
>>             3) The html metadata browser is quite simple, and we can
>>             extend it in QGIS 2.1.
>>             For example, some tags can be clickable and set a new
>>             filter (filter by clicked
>>             author/tag/status). Also the separate buttons
>>             Install/Uninstall can be
>>             implemented by html "buttonsm", and the popup dialog with
>>             installation progress
>>             can be replaced by animated image (this way we don't
>>             freeze the gui when installing).
>>             Code:
>>             http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginmanager.h
>>             http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginmanager.cpp
>>             *QgsPluginSortFilterProxyModel*
>>             New class: just a sort-filter proxy for the metadata.
>>             Filtering is done by status
>>             in the left list as well as name/description/tags/author
>>             in the filter input line.
>>             Sorting is done by rightclicking on the list. Foltering
>>             and sorting is based
>>             on a few user data roles. I tried to read necessary data
>>             from mPlugins everytime,
>>             but it affected the performance too much.
>>             Code:
>>             http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginsortfilterproxymodel.h
>>             http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginsortfilterproxymodel.cpp
>>             *QgsAppPluginManagerInterface, QgsPluginManagerInterface
>>             and SIP binding*
>>             New classes: just the interface to QgsPluginManager. Is's
>>             exactly based
>>             on the existing Qgs(App)LegendInterface
>>             Code:
>>             http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/python/gui/qgspluginmanagerinterface.sip
>>             http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/gui/qgspluginmanagerinterface.h
>>             http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/gui/qgspluginmanagerinterface.cpp
>>             http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgsapppluginmanagerinterface.h
>>             http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgsapppluginmanagerinterface.cpp
>>             QgisApp
>>             Small change: initialize the QgsPluginManager and Python
>>             module
>>             pyplugin_installer in the constructor. Only open the
>>             QgsPluginManager window
>>             when called from the main menu.
>>             Diff:
>>             http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisapp.h
>>             http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisapp.cpp
>>             QgisAppInterface and QgisInterface and SIP binding
>>             Small change: instantiate Qgs(App)PluginManagerInterface
>>             exactly the same way as Qgs(App)LegendInterface
>>             Diff:
>>             http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisappinterface.h
>>             http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisappinterface.cpp
>>             pyplugin_installer Python module
>>             New python module in python/pyplugin_installer. It
>>             contains just slightly refactored
>>             code of the old plugin_installer plugin and provides
>>             backend for handling Python
>>             plugis, e.g.: fetching remote repositories, loading
>>             installed plugin metadata, finding
>>             upgradeable plugins, (un)installing python plugins etc.
>>             It's methods are called from
>>             QgsPluginManager and it calls QgsPluginManager methods
>>             via QgsPluginManagerInterface.
>>             Code:
>>             http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/show/python/pyplugin_installer
>>             _______________________________________________
>>             Qgis-developer mailing list
>>             Qgis-developer at lists.osgeo.org
>>             <mailto:Qgis-developer at lists.osgeo.org>
>>             http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>         Dr. Marco Hugentobler
>>         Sourcepole -  Linux & Open Source Solutions
>>         Weberstrasse 5, CH-8004 Zürich, Switzerland
>>         <mailto:marco.hugentobler at sourcepole.ch> http://www.sourcepole.ch
>>         Technical Advisor QGIS Project Steering Committee
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130605/ce8f03c7/attachment-0001.html>
