[Qgis-developer] Bug working with size in data-defined properties?
Marco Hugentobler marco.hugentobler at sourcepole.ch
Fri Jun 7 04:00:36 PDT 2013
Hi
Check if you have activated Advanced -> Size scale Field -> Scale area /
scale diameter
In the first case, size means actually area with data defined symbology.
Regards,
Marco
On 07.06.2013 12:28, Jordi Torres wrote:
> Hi Régis,
> Thanks for the testing. I think it's not multiplied by a defined
> factor at all, divide by 0.2 and you still won't get the desired size.
> Cheers.
> 2013/6/7 Régis Haubourg <regis.haubourg at eau-adour-garonne.fr
> <mailto:regis.haubourg at eau-adour-garonne.fr>>
>     Hi,Confirmed for me.
>     It looks like size is multiplid by a factor 0.2.
>     6 value in data defined looks like 1,2 on screen. 1 look like 0,2.
>     BTW behaviour is not clear since old advanced properties (proportion /
>     rotation) have not been removed AND have a different behaviour.
>     They do not
>     use actual value, but act as a modifier of symbol size. New
>     behaviour is by
>     far better! (still lacks options to use non linear fonctions.. but
>     it still
>     is very nice)
>     Can anybody explains that newbehaviour and it interfers with data
>     defined
>     style?
>     Régis
>     View this message in context:
>     http://osgeo-org.1560.x6.nabble.com/Bug-working-with-size-in-data-defined-properties-tp5058657p5058663.html
>     Sent from the Quantum GIS - Developer mailing list archive at
>     Nabble.com.
>     _______________________________________________
>     Qgis-developer mailing list
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Jordi Torres
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130607/890c90e5/attachment-0001.html>
