[Qgis-developer] SIP API Update merged. Attention plugin authors
Matthias Kuhn matthias.kuhn at gmx.ch
Sun Jun 9 07:56:16 PDT 2013
And the NULL values?
try:
   a = float(b['c'])
except TypeError:
   a = None
Do you have a more elegant idea?
On Son 09 Jun 2013 16:46:42 CEST, Victor Olaya wrote:
> I think it is a good idea to force the data type using str(),
> unicode(), int(), float(), etc... Maybe a bit redundant, but probably
> a safer strategy now
> 2013/6/9 Matthias Kuhn <matthias.kuhn at gmx.ch>:
>> Just found another case which requires special attention:
>> Given a feature with myInt=5
>> Old API:
>>> feat['myInt'].toFloat() / 10
>>> 0.5
>> New API:
>>> feat['myInt'] / 10
>>> 0
>> Better:
>>> float( feat['myInt'] ) / 10
>>> 0.5
>> Or:
>>> feat['myInt'] / 10.0
>>> 0.5
>> I guess that's not something we can fix in a generic way, but something
>> to keep in mind when updating a plugin.
>> On Son 09 Jun 2013 16:38:09 CEST, Victor Olaya wrote:
>>> I find that same behaviour that Matthias confirms.
>>> I guess it should be fixed, since it forces developers to add extra
>>> code to handle that case, and it can be very confusing (all other
>>> Qvariants are removed, except in this case...)
>>> Hopefully it will be easy to fix.
>>> Thanks in advance!
>>> Victor
>>> 2013/6/9 Nathan Woodrow <madmanwoo at gmail.com>:
>>>> Ok I'll check it out and see if it can be converted.
>>>> -- Nathan
>>>> On Mon, Jun 10, 2013 at 12:19 AM, Matthias Kuhn <matthias.kuhn at gmx.ch>
>>>> wrote:
>>>>> On Son 09 Jun 2013 16:02:57 CEST, Nathan Woodrow wrote:
>>>>>> Victor,
>>>>>> Which code is returning a QVariant null?
>>>>> feat['myAttribute']
>>>>> returns QPyNullVariant for all features which have a NULL value in the
>>>>> field myAttribute.
>>>>> None would work for me as well. But I'm not sure, why PyQt introduced
>>>>> this new type. Maybe there is a reason?
>>>>> Matthias
>>>>>> - Nathan
>>>>>> On Mon, Jun 10, 2013 at 12:01 AM, Victor Olaya <volayaf at gmail.com
>>>>>> <mailto:volayaf at gmail.com>> wrote:
>>>>>>     I am checking the SEXTANTE adaptation to the new SIP API, and
>>>>>>     everything is fine. The only "strange" thing that I found is how
>>>>>> null
>>>>>>     values are handled when they appear in a vector layer field. It
>>>>>> seems
>>>>>>     that, in that case, a QVariant is still returned (particularly a
>>>>>>     QPyNullVariant object). Wouldn't it be better to return a Python
>>>>>> None
>>>>>>     instead, so in all cases Python values are returned?
>>>>>>     Cheers
>>>>>>     2013/6/9 Richard Duivenvoorde <rdmailings at duif.net
>>>>>>     <mailto:rdmailings at duif.net>>:
>>>>>>     > On 09-06-13 10:47, Nathan Woodrow wrote:
>>>>>>     >> Technically this can be done for smaller plugins like Borys said.
>>>>>>     >>   Something like:
>>>>>>     > I think only for VERY small plugins. In the (not so very big
>>>>>>     plugins) I do
>>>>>>     > it was already getting messy.
>>>>>>     > And by the why, a big thank you for all the great work and
>>>>>>     decisions being
>>>>>>     > done lately! I really think 2.0 will be great \o/
>>>>>>     > Richard
>>>>>>     > _______________________________________________
>>>>>>     > Qgis-developer mailing list
>>>>>>     > Qgis-developer at lists.osgeo.org
>>>>>>     <mailto:Qgis-developer at lists.osgeo.org>
>>>>>>     > http://lists.osgeo.org/mailman/listinfo/qgis-developer
