[Qgis-developer] SIP API Update merged. Attention plugin
Nathan Woodrow madmanwoo at gmail.com
Sun Jun 9 08:05:12 PDT 2013
 authors
MIME-Version: 1.0
Content-Type: text/plain; charset="utf-8"
Content-Transfer-Encoding: 7bit
There isn't a fix for this because it's not a bug. You column is a int
and python is giving you a int. The correct 1:1 conversion is
float(touring) / 10
Sent from some fancy phone looking thingo
Sent: 10/06/2013 12:42 AM
To: Victor Olaya
Cc: Richard Duivenvoorde; qgis-developer at lists.osgeo.org; Nathan Woodrow
Subject: Re: [Qgis-developer] SIP API Update merged. Attention plugin
authors
Just found another case which requires special attention:
Given a feature with myInt=5
Old API:
> feat['myInt'].toFloat() / 10
> 0.5
New API:
> feat['myInt'] / 10
> 0
Better:
> float( feat['myInt'] ) / 10
> 0.5
Or:
> feat['myInt'] / 10.0
> 0.5
I guess that's not something we can fix in a generic way, but something
to keep in mind when updating a plugin.
On Son 09 Jun 2013 16:38:09 CEST, Victor Olaya wrote:
> I find that same behaviour that Matthias confirms.
> I guess it should be fixed, since it forces developers to add extra
> code to handle that case, and it can be very confusing (all other
> Qvariants are removed, except in this case...)
> Hopefully it will be easy to fix.
> Thanks in advance!
> Victor
> 2013/6/9 Nathan Woodrow <madmanwoo at gmail.com>:
>> Ok I'll check it out and see if it can be converted.
>> -- Nathan
>> On Mon, Jun 10, 2013 at 12:19 AM, Matthias Kuhn <matthias.kuhn at gmx.ch>
>> wrote:
>>> On Son 09 Jun 2013 16:02:57 CEST, Nathan Woodrow wrote:
>>>> Victor,
>>>> Which code is returning a QVariant null?
>>> feat['myAttribute']
>>> returns QPyNullVariant for all features which have a NULL value in the
>>> field myAttribute.
>>> None would work for me as well. But I'm not sure, why PyQt introduced
>>> this new type. Maybe there is a reason?
>>> Matthias
>>>> - Nathan
>>>> On Mon, Jun 10, 2013 at 12:01 AM, Victor Olaya <volayaf at gmail.com
>>>> <mailto:volayaf at gmail.com>> wrote:
>>>>     I am checking the SEXTANTE adaptation to the new SIP API, and
>>>>     everything is fine. The only "strange" thing that I found is how
>>>> null
>>>>     values are handled when they appear in a vector layer field. It
>>>> seems
>>>>     that, in that case, a QVariant is still returned (particularly a
>>>>     QPyNullVariant object). Wouldn't it be better to return a Python
>>>> None
>>>>     instead, so in all cases Python values are returned?
>>>>     Cheers
>>>>     2013/6/9 Richard Duivenvoorde <rdmailings at duif.net
>>>>     <mailto:rdmailings at duif.net>>:
>>>>     > On 09-06-13 10:47, Nathan Woodrow wrote:
>>>>     >> Technically this can be done for smaller plugins like Borys said.
>>>>     >>   Something like:
>>>>     > I think only for VERY small plugins. In the (not so very big
>>>>     plugins) I do
>>>>     > it was already getting messy.
>>>>     > And by the why, a big thank you for all the great work and
>>>>     decisions being
>>>>     > done lately! I really think 2.0 will be great \o/
>>>>     > Richard
>>>>     > _______________________________________________
>>>>     > Qgis-developer mailing list
>>>>     > Qgis-developer at lists.osgeo.org
>>>>     <mailto:Qgis-developer at lists.osgeo.org>
>>>>     > http://lists.osgeo.org/mailman/listinfo/qgis-developer
