[Qgis-developer] SIP API Update merged. Attention plugin authors
    Radim Blazek
    radim.blazek at gmail.com
    Mon Jun 10 06:36:54 PDT 2013
I am getting error on startup:
An error occured during execution of following code:
pyplugin_installer.instance().showPluginManagerWhenReady()
url = settings.value(key+"/url", "", type=unicode)
TypeError: QSettings.value(QString, QVariant defaultValue=QVariant()):
'type' is not a valid keyword argument
I have qt 4.6.3,  python-qt4  4.7.3, python-sip4 4.10.2. Form INSTALL:
Required build deps:
- Qt >= 4.4.0
Optional dependencies:
- for python support - SIP >= 4.8, PyQt >= must match Qt version, Qscintilla2
so it should be sufficient.
Radim
On Sat, Jun 8, 2013 at 1:35 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Hey all,
> The new SIP API has been merged now.  There are still a few things to clean
> up in some of the core plugins but it is merged for wider testing.   I don't
> expect to find any major issues.
> I have written a conversion guide here:
> https://gist.github.com/NathanW2/5734767
> Plugin authors could you take some time to update you plugins so they will
> be ready for 2.0 once it is released _however_ please don't upload the new
> 2.0 version of your new plugin to the QGIS plugin repo until I give you the
> go ahead as we need to do a update on the server so that 1.8 will not get
> the 2.0 plugins because they will not run in 1.8.
> I would recommend creating a branch in git with your new 2.0 version and be
> ready to upload it when I give the go ahead.
> Note: 1.8 plugins will not run in 2.0 without being updated to the new API
> syntax. 2.0 plugins will not work in 1.8.
> Users who live on the edge by running the dev build please just bare with us
> while we get this sorted out, shouldn't take too long.
> Email me if you have any issue.
> Regards,
> Nathan
> Qgis-developer mailing list
