[Qgis-developer] Openlayers plugin in 2.0 Was: QGIS 2.0 release and plugins
    Richard Duivenvoorde
    rdmailings at duif.net
    Sun Jun 16 01:30:59 PDT 2013
On 16-06-13 00:39, Anita Graser wrote:
> I'm a bit worried about not having a functioning Openlayers plugin in
> QGIS 2.0 for two months.
> Can someone with experience in porting plugins estimate how much work it
> really is to make it compatible with the new API
Hi Pirmin,
if we manage to release 2.0 before Brighton, I agree that the Openlayers
plugin is one plugin which should be available at 2.0 launch.
Here locally I managed to get it running in current master (most of it,
overview widget is not ok yet).
But I do not want to force/stress Sourcepole or Matthias to put time in
looking into it if they have more important things to do.
And maybe you have (bigger/other) plans with the plugin, like a
refactoring or upgrade of bigger parts of the code. Or maybe you know
with QGIS 2.0 there are non sip parts that will give problems?
I can also imagine that you really want to support only ONE plugin
working for both sip api versions.
But that said, I'm happy to put what I have now put on Github and ask
for a pull request in a 2.0 branch (what I did is NOT compatible with
1.8). I'm also available if bugs pop up in that version in short future.
And I agree that Brighton is then a nice place to do the 'bigger' work
for this really important plugin.
Regards,
