[Qgis-developer] Update map bug in master
Matthias Kuhn matthias.kuhn at gmx.ch
Tue Jun 18 02:36:19 PDT 2013
Hi Jakob,
Thank you for reporting this issue.
Could you open a bug in the issue tracker [1]
It will be much easier to follow there and track the status of the
issue.
Regards,
Matthias
[1] http://hub.qgis.org/projects/quantum-gis/issues
On Die 18 Jun 2013 11:30:16 CEST, Jakob Lanstorp wrote:
> If one runs a 'Select by location' in QGIS 1.9.0-Master, the map is not
> updated with the new selection. If you, after running the algorithm,
> manually press the Refresh map button the selection becomes visibly.
> Jakob
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Update-map-bug-in-master-tp5060810.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
