[Qgis-developer] Relative paths in mapserver
Marco Hugentobler marco.hugentobler at sourcepole.ch
Wed Jun 19 13:35:55 PDT 2013
 >There was a bug opened about this problem :
 >Bug #8027: qgis-server don't understand correctly the relative path in
a spatialite db
This is a different thing. Relative pathes _within_ the project should
be considered if project path setting is 'relative pathes'. (I remember
that was fixed somewhen for spatialite).
 >I'm finding problems in using relative paths in qgis mapserver.
Relative pathes _to_ the project file are currently not supported
(though it is easy to resolve the relative pathes). What is your
use-case? Do you have several different server instances on your machine?
Regards,
Marco
Am 19.06.2013 09:01, schrieb rldhont:
> Hi Paolo,
> a spatialite db
> http://hub.qgis.org/issues/8027
> This bug has been closed because he was not enough generic.
> You can reopen this one or open a new one.
> René-Luc D'Hont
> 3Liz
> Le 18/06/2013 19:26, Paolo Cavallini a écrit :
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Hi all.
>> The following request works:
>> http://192.168.0.79/cgi-bin/qgis_mapserv.fcgi?map=/usr/lib/cgi-bin/test/test.qgs&SERVICE=WMS&REQUEST=GetMap&BBOX=15,20,50,40&CRS=EPSG:4326&WIDTH=800&HEIGHT=480&LAYERS=comuni&FORMAT=image/png
>> while this one does not (returns a white page):
>> http://192.168.0.79/cgi-bin/qgis_mapserv.fcgi?map=test/test.qgs&SERVICE=WMS&REQUEST=GetMap&BBOX=15,20,50,40&CRS=EPSG:4326&WIDTH=800&HEIGHT=480&LAYERS=comuni&FORMAT=image/png
>> Am I doing something wrong?
>> All the best.
>> - -- Paolo Cavallini - Faunalia
>> www.faunalia.eu
>> Full contact details at www.faunalia.eu/pc
>> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.12 (GNU/Linux)
>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
>> iEYEARECAAYFAlHAmCsACgkQ/NedwLUzIr5J+wCgoHiV+pdYuJCoh8LyMeRU4jZN
>> oXQAn37T0LnXvUyb1eOvvwrJNyay+m6c
>> =G6NJ
>> -----END PGP SIGNATURE-----
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
