[Qgis-developer] Problems with Atlas and Map dimensions on composer using Python
    Alexander Bruy
    alexander.bruy at gmail.com
    Mon Jun 24 09:17:11 PDT 2013
I have similar issue: composer map changes its dimensions when
scale and extents changed. I posted question in this list some time
ago [0].
Seems it is impossible to keep composer map size and position
locked. IMO this is big issue that makes composer templates
useless in some cases.
[0] http://www.mail-archive.com/qgis-developer@lists.osgeo.org/msg15587.html
2013/6/24 Stott James <fmrojst at fylkesmannen.no>:
> Hi all,
> Is anyone else having problems with using atlas with python?
> I am writing some python code that uses the Atlas functionality in master to
> create a PDF / jpg for each of my 5000 records.
> I can produce a jpg/pdf for each feature, however the composerMap object
> does not stay the same size.
> I found this bug report which describes the issue. This report is listed as
> fixed:
> http://hub.qgis.org/issues/6956
> I have set the following two lines in my code:
> myAtlas.setFixedScale( False )
> myAtlas.setMargin(0.1)
> If I set this up from within QGIS, it works perfectly. It is only through
> Python I have problems.
> Here are the example exported jpgs:
> Generated inside QGIS GUI
> https://docs.google.com/file/d/0B6r5nAOdEBZrbFk0UUdxOVdTRVk/edit?usp=sharing
> Generated from python
> https://docs.google.com/file/d/0B6r5nAOdEBZrZVJmWlpBb1c4Q2M/edit?usp=sharing
> I have also included a stripped down version of my code, along with a sample
> shapefile (this isn’t the data I am planning to use it with, but it doesn’t
> work with either the sample or the real data).
> https://docs.google.com/file/d/0B6r5nAOdEBZrRUpzZm81cU1pUkk/edit?usp=sharing
> Using master, updated today from OsGeo4W.
> Many thanks,
> James Stott
Alexander Bruy
