[Qgis-developer] Volume between two surfaces
Maris Nartiss maris.gis at gmail.com
Wed Mar 6 00:06:37 PST 2013
Hello,
I would go for plain GRASS raster algebra solution.
diff = top_dem - bottom_dem # difference between two surfaces in DEM units
positive = if (diff < 0, 0, diff) # remove any errors/places where
excavation is higher than original
r.sum raster=positive
g.region -p
and multply r.sum output with size of single cell from g.region.
Take into account that large cells will produce larger uncertainty as
each cell is treated as a square prism.
Hope it helps,
Maris.
2013/3/6 Pedro Venâncio <pedrongvenancio at yahoo.com>:
> Hi all,
> Is there any way to calculate the volume between two surfaces (two DEM rasters)?
> There are ways to calculate the volume between a surface and a particular height value (GRASS r.volume or SAGA Grid Volume) but I can not find how to calculate the volumes (landfill / excavation) between two DEM.
> Any tips?
> Thank you very much!
> Best regards,
> Pedro Venâncio
> Qgis-developer mailing list
