[Qgis-developer] Missing icons qgis-dev OSGeo4W
Nathan Woodrow madmanwoo at gmail.com
Fri Mar 8 03:33:47 PST 2013
No I had everything installed.  I'm just going to nuke my install and redo
the whole lot in case something got messed up.
- Nathan
On Fri, Mar 8, 2013 at 9:32 PM, Larry Shaffer <larrys at dakotacarto.com>wrote:
> Hi Nathan,
> On Thu, Mar 7, 2013 at 11:01 PM, Nathan Woodrow <madmanwoo at gmail.com>wrote:
>> Thanks.  They are both empty.  Can they be installed using OSGeo4W?
> That's odd; seems like those dlls should always be installed along with
> 'qt4-libs'. Means that Qt run time currently only has built-in support for
> PNG. Did you just install 'qt4-devel' and not 'qt4-libs' ?
> Regards,
> Larry
>>  - Nathan
>> On Fri, Mar 8, 2013 at 3:58 PM, Larry Shaffer <larrys at dakotacarto.com>wrote:
>>> Hi Nathan,
>>> On Thu, Mar 7, 2013 at 8:36 PM, Nathan Woodrow <madmanwoo at gmail.com>wrote:
>>>> I have just updated my OSGeo4W install and a lot of the icons for my
>>>> qgis-dev build are missing.  Just blank push buttons for things like Enable
>>>> Editing, most of the label options, and some of the other tools.
>>>> Anyone know what be causing this, or a way to fix it?
>>> Sounds like an issue with SVG rendering. Those are some of the newer
>>> icons that have been switched over to SVG-only (regardless of theme). Maybe
>>> check your C:\OSGeo4W\apps\qt4\plugins dir in imageformats and iconengines
>>> to make sure your Qt SVG dlls are actually there?
>>> Regards,
>>> Larry
>>>> - Nathan
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130308/c92212eb/attachment.html>
