[Qgis-developer] No rule to make target staged_plugins
Sandro Santilli strk at keybit.net
Tue Mar 12 03:09:02 PDT 2013
On Tue, Mar 12, 2013 at 10:34:28AM +0100, Radim Blazek wrote:
> On Tue, Mar 12, 2013 at 10:18 AM, Sandro Santilli <strk at keybit.net> wrote:
> > On Tue, Mar 12, 2013 at 10:05:59AM +0100, Radim Blazek wrote:
> >> On Mon, Mar 11, 2013 at 6:46 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
> >> > Hi Radim,
> >> > Could you start an issue ticket for this, possibly including some specs,
> >> > like which version of cmake, compiler, etc.? I can not discern what might be
> >> > causing the problem for your setup, but working for everyone else (I'm
> >> > assuming that), and would like to exchange some patches since I can't
> >> > reproduce it here.
> >> We have enough serious issues, is not sufficient to set
> >> WITH_STAGED_PLUGINS=OFF by default?
> > I think the default should be that output/bin/qgis works and can load
> > all new core plugins, so developers can test and users can use multiple
> > versions. That seems to currently mean "staged plugins".
> > I can't find any issue filed on hub where [Subject contains "staged"]
> > You mentioned that WITH_STAGED_PLUGINS=OFF works for you, right ?
> > Does "make staged-plugins" work after that ?
> Yes, as I already reported. It is
>    make staged-plugins-on-build
> causing the problem:
>    *** No rule to make target `staged-plugins', needed by
> `python/plugins/CMakeFiles/staged-plugins-on-build'.  Stop.
Do you have a `python/plugins/CMakeFiles/staged-plugins-on-build.dir'
directory ? What version of cmake are you running ?
--strk;
