[Qgis-developer] Blend modes for labels?
Andreas Neumann a.neumann at carto.net
Thu Mar 28 01:21:35 PDT 2013
 Ah right - it is already available - cool!
 So it can be found in the label settings dialogue. Just testing now.
 Thanks,
 Andreas
 On Thu, 28 Mar 2013 09:15:43 +0100, Marco Hugentobler wrote:
> Wasn't that introduced in 8793d388b1fd0f315f55b0f56f5ee8462ea6df13 ?
> Regards,
> Marco
> On 28.03.2013 09:09, Andreas Neumann wrote:
>> Hi,
>> I noticed that the blend modes do not have any effect on labels.
>> I was trying to see if one of the blend modes could help to label
>> orthophotos where you have the problem that the photo varies a lot in
>> brightness - there are dark and bright regions next to each other and
>> therefore neither a dark or bright text really works well. I wanted to
>> test if one of the blend modes could fix that problem.
>> Any chance that the blend modes could also work on labels?
>> Thanks,
>> Andreas
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
