[Qgis-developer] Git help needed
MORREALE Jean Roc jr.morreale at enoreth.net
Thu May 2 02:03:20 PDT 2013
Hi Werner,
Thank for the answer, I already tried git reset but got stuck on that :
$ git reset --hard upstream/master
fatal: ambiguous argument 'upstream/master': unknown revision or path
not in the working tree.
Use '--' to separate paths from revisions, like this:
'git <command> [<revision>...] -- [<file>...]'
But applying the command 'git remote update' before it did the trick !
I didn't knew this command, should it be used instead of fetch/pull
upstream ?
