[Qgis-developer] Git help needed
MORREALE Jean Roc jr.morreale at enoreth.net
Thu May 2 06:02:49 PDT 2013
I've the same process/repo names than described on your blog, the
exception is 'git pull --rebase upstream master'. You're using it before
or after a add/commit ?
Le 02/05/2013 14:48, Werner Macho a écrit :
> Hi JR
> It all depends how YOU called your "upstream" .. your fork on github
> after cloning is always called "origin" ..
> The rest depends which repository you cloned and which one is the remote
> attached ..
> You can take a look at:
> http://quantumofgis.blogspot.co.at/
> there i explained "my" workflow for translations ..
> I will extend that with a GRASS entry in the next few weeks too - and
> afterwards I'll move to branching and merging explanations .. :)
> git is not THAT difficult once you are used to it ..
> regards
> Werner
> On Thu, May 2, 2013 at 11:03 AM, MORREALE Jean Roc
> <jr.morreale at enoreth.net <mailto:jr.morreale at enoreth.net>> wrote:
>     Hi Werner,
>     Thank for the answer, I already tried git reset but got stuck on that :
>     $ git reset --hard upstream/master
>     fatal: ambiguous argument 'upstream/master': unknown revision or
>     path not in the working tree.
>     Use '--' to separate paths from revisions, like this:
>     'git <command> [<revision>...] -- [<file>...]'
>     But applying the command 'git remote update' before it did the trick !
>     I didn't knew this command, should it be used instead of fetch/pull
>     upstream ?
